Hi All,
Everything appears to be working ok.
The issue with the display was the contrast control on the back of the SPI display controller.
Running the display with 3.3V I had to set the contrast control pot to its limit and it is still not very good.
Lucky I provided a 5V backlight option and the contrast is much better.
In order to use the SPI display controller in 5V mode you need to remove two pull up resistors on the SPI controller pictured below labelled R8 and R9.
You also need to add 2 x 4.7k pull up resistors on the main board.
There is a spare header on the main board for the 5V option.
Before I can test with a coil am expecting to receive the surface mount IRFP9640S next week .
in the meantime I will be adding the encoder and testing the audio circuitry over the weekend.
When all this is done and dusted will start a new thread where I will post all the files.
