Subsitute components
  • Subsitute components
    What can i use as a subsitute for 2n5485 and mpsa13 transistors for the geotech baracuda?
    the 2N5485 (N-Ch Fet) you can replace with a J113 and the MPSA13 (NPN-Darlington) can be replaced with a BC337. But you need to place it into the PCB the "mirrowed way" because
    the pin pattern is reverse compare to the MPSA13, meaning the MPSA13 has a EBC (123) pin pattern and the BC337 has a CBE (321) pin pattern.
    In case you make a new PCB design, I would rightaway use components which are easy to find.​
      i am unable to find j113 got bc337, can i use j112 instead?
        Use 2N3819 or MPF102 for MPSA13 use BC517 be careful to check datasheet for pinout
          cant find those too i will try maybe j113 and bc 337, i can get the j113 from a different seller i just wanted all my components from one but they only have j112
            Pay attention to the cutoff voltage spec. The J112 might work, might not.
              do you need direct links on chineses? why you can not buy them?
                I would be careful buying from aliexpress from China​! Sometimes marked components are not really always original​, so it may confuse you that it doesn't work​! For natural persons, it happens that the components are not checked​ , of course, he will never be embarrassed if the company orders him​, although at Volvo there is a team that checks the components before installation​, probably in other serious companies as well​...
                  the chinese thing i got some which were really expensive or not available but it took me about 3 months, i wanted to get them locally if possible
                    locally is mean Africa? do you want be anonime?
                      No buddy I live in india
                        India is 1.4 billion population... it is biggest industry of any electronics in the world... feeling i must not suggest you be cause my county does nothing.
                        just idiocraсy.
                          i mean it has very general stuff but when i look for some parts you either have to pay a lot or get them from ebay which takes a lot of time also even aliexpress is banned here leave ordering stuff from it
                            ok. i give you full list i wrote for TIS
                            TIS75 - BFS74, BFS76, BFS77, BFS79, BSV78, BSV79, BSV80, 2N3970, 2N4093, 2N4391, 2N4858, 2N4861
                              fets_pinouts.pdf
                              TIS75 2N table.pdf
                              TIS75 cross.pdf
                              2N4393_table.pdf
