What should be the data format between the gradio meter and the 3d program?
  • What should be the data format between the gradio meter and the 3d program?
    Hello.
    I want to make a gradio meter with flc-100 sensors (ems-100) myself. I designed a pcb with 40cm distance between 2 sensors on a single card.
    There are 18f25k22 - 12f683 and hc-05 that will work with them on the card. There is also eps32 on the same card. I am making a separate software for each of them.
    2 sensors directly enter the processor and I can take the difference and process through the software. So I have no problem in processing the data coming from the sensors.
    But I don't know how to send this data to any 3d software.
    I have some documents, one of them belongs to "Bartington_Grad601_om1800".
    but it is not very descriptive information.
    I don't want to write a 3d software myself instead. As a last resort, I can do it in android studio. But I'm not thinking right now.
    Instead, I want to work with the "FS Future Series - Visualizer 3D" program and have my own card send data directly to this program.
    But I couldn't find any information on how to send information in which format. Can you help me with this?
    So, in short, I need some information:
    I'm wondering what kind of data the program wants, with the sequence of operations, as if you are going to send the measured value for this input to the program in this format and then send the following information. I need this.​
