PI-1 questions
  • PI-1 questions
    Carl,
    First of all, many thanks for creating this project! It looks like it should be really interesting to experiment with.
    After reading your latest manual for the PI-1, I've decided to build the Option 1 version with the addition of the Q3 active cutoff. I'd also implement the output filtering of the NE5534 if I understood its purpose. If some commercial PI detectors use it, one would think this filtering would serve some purpose. However, when you state that some manufacturers use the low-pass and others use the high-pass filter option, that confuses me as to the advantage or purpose of either.
    Most importantly, I want to build a PI detector that can serve well in practical use while retaining the experimental options you have designed into it. As such, I'd like to build a detector with the most useful adjustments appearing as external controls, a number of trimpots accessible with the case closed (mounted on a perfboard aligned with holes drilled into the case) for the most useful experimental adjustments and, if applicable, the adjustments needed only for calibration limited to less accessible trimpots on the PCB. Since I've only owned IB detectors up until now, can you give me an idea of which potentiometers fit into each category mentioned.
    On another subject, would there be any advantage in using the very slightly more expensive NE5534A (rated lower noise) version of the NE5534 in your design?
    Thanks,
    Bill Blair
    Re: PI-1 questions
    Sorry for not getting to your email. I've seen high-pass on the SMPI and Barracuda, and low-pass on 1 or 2 others, I don't recall which. LPF might be for thermal noise, and HPF might be for low-freq interference. I haven't played with this yet, and off the top of my head, can't remember if past discussions have dealt with this. I threw in placeholders for the components, in case anyone wanted to try it.
    I would set the freq, pulse width, sample width, sec. sample delay, volume, autotune speed, and sensitivity with trim pots. Use control pots for threshold and sample delay, plus a power switch, and an autotune switch.
    I doubt you will see a difference between the 5534 and 5534A.
