Deep of the Hammerhead
  • Deep of the Hammerhead
    Have anyone infos about the deep and identify objects ?
    Depth
    It can detect large objects at 2.5 to 3m with 1m x 1m coil.
      How large is large?
      F.
        Good question
        Originally posted by Functional View Post
        How large is large?
        F.
        good question How large is large
          hh
          hemmerhead is best for 11" coil best designe
            hh
            hi if you modified r1 r2 r3 r4 mean's 100hz frequency and 256 us pulse width for 1m /1m coil it goe's 2.5 meter at large metal
              I have built a Hammerhead. I would like to build 1 * 1 meter coil, 0.75 mm2 (1 mm in diameter) solid copper pipeline Electrician (MCU).
              How many turns of the coil?
              What are the main values to set the sample delay, pulse widht, widht sample, sec. sample delay and frequency.
              Thank you.
              Sorry I'm bad in English.
                Thank you.
                I have built the 1*1mcoil for HH. It is detect a Coke at 1,3m in air. Is it good?
                  Yes, it is excellent. Congratulations.
                    why nobody explain about how large ?
                      because this is relaited from some condition. if you are working on PULSE WIDTH 100us you get one depth. if you are working on 1000 ms you get another more deep depth. so NOBODY do not explain you about how large it is.
