I think (I´m almost sure) that I´m doing something wrong, but I can´t realize what.
The problem is that R18 potentiometer doesn´t have any effect on the signal on TP4. Following the calibration instructions (thanks again Carl), there is nothing to do with the components, I mean, all of them installed.
Measuring the circuit those are the results: the inputs of the preamp should be equal, and so them are, but the output is VB+5.
I´m using Lab power supplies to generate 10, 5 and 15 volts. I tried to disconnect TP3, to connect in- to in+ and to connect in- to VB but R18 doesn´t have any effect.
I suppose the out of IC6 should be VB when there is no pulse on the coil, shouldn´t it?
I don´t know what else to do!!
