Bandito TX Frequency
  • Bandito TX Frequency
    Well it's another Snowy cold winter here in Upstate NY and I am thinking of building a VLF detector based on the Bandito circuit for a winter project. I have searched all over and can't seem to find the TX frequency of that unit. I believe it is around 10 KHz. Could someone please let me know for sure what it actually is.
    Russ
    Scope pictures
    If you can see the freq measurements.
      I mean
      oops
        Re: Scope pictures
        Hi Goodrat
        Where I found P28, P24 and P23 on the Bandido schematic ?
          Thanks Goodrat
          Thanks A bunch Goodrat. I haven't built anything just yet I am in the process of doing the circuit board layout. So it looks like 10.2 Khz for the one you are measuring. I probably will take my time with this project since I doubt if I will even see the ground around here much till sometime in March. I still also need to do a new layout and board for an adaptation of Carl's Hammerhead that I have built. Well at least it's something to pass the time through winter. Thanks again and have a good one.
          Russ_NY
            P28,24,23
            Sorry, I have those marked on my schematic.
            P28 is (-) input of IC7B
            P24 is the output of IC5B
            P23 is at C18
            This is what is on the legend of my Cutlass II.
              Re: P28,24,23
              Hi Goodrat
              Many thanks. What is signal level (rest state) on output of IC7A ?
