I should check? 10cm depth
  • I should check? 10cm depth
    my tgsl detects a coin and something bigger 6cm to 10cm that I review to increase its depth TX works with 200mV is only for the moment that I can measure, I'll have to change the value of some capacitors and the coils are made ​​as is detailed in the post.
    some days will have an oscilloscope can someone tell me what points should I test the pcb could point me in the scheme
    thank you very much.
