Stable damping resistor
  • Stable damping resistor
    This is an adjustable damping resistor made with temperature stable resistors (25 parts per million / per degree)
    So, even with a temperature variation of 100 degrees it should not vary by more than 0.25%
    Compared to carbon resistor 200ppm (2% variation over 100 degrees)
    Metal film is more stable, but could still be ~100ppm (1% over 100 degrees)
    Adjustable from 200ohm to 1200ohm with 25 ohm increments using the solder-bridges
    Will that be able to handle the power?
      No
      With 1/4 Watt resistors, they are running warm and out of spec, with a detector that pumps 1 Watt average power into them.
      Attached is an improved circuit,
      Using 1/4 Watt, 1206, resistors it will run comfortably with 1 Watt average power.
