Probe coil for Baracuda pi?
  • Probe coil for Baracuda pi?
    I ordered one of the kits for the Baracuda Pi from Silverdog. I am wondering if it would work with a small probe coil like a pin pointer. I figure I could use it with a cord and belt mount the control. I mostly plan on using this as a beach detector but thought this might also be a good use when not at the beach. If its possible then what would be the best design for such a coil. I am a beginner so please use small words Thanks
    it certainly will work with a small coil
    you could wind a 2-4" coil or wind onto a ferrite rod
    as long as the coil inductance is similiar to the stated spec it will be fine
    remember though you will need to move the coil, the baracuda is a motion detector
    I made a small pinpointer with a ferrite rod http://www.youtube.com/watch?v=zq1JTMJmFjQ
    the same kind of thing would work ok
      Thanks thats great. Are any of the PI kits available no motion detectors? I might try one of them next. Or is there a mod to make the Baracuda no motion?
        I've yet to find a proven non-motion design
        with a ferrite rod you only need to wiggle it an inch or so each way so its not too bad
          Hi
          I didnt realize the baracuda was motion type, although never built ive got the bits pcb etc to build one apart from the transistors.
          The Minipulse3 project is non motion and works well , the draw back is wight and power consumption but yet to try a small pinpoint coil for it.
          Will try and let you know results.
          Dave
            hello
            minipulse3 is too mch for a pinpointer
            try pulsdetektor boeses tier 1
            or surf pi with pinpoint mod
            i have made a tube /pinpointer coil for surf pi in motion mode
            http://www.youtube.com/watch?v=oaCyVGAuYX0
            this type will work similar for baracuda
              hello
              Thats quite impressive, and your MD build, Was that built round a core or just wound round a form?
              What was the specs?
              Well done
                hello satdaveuk
                coil is wound on pvc pipe 20mm or 25mm diameter
                cable is litz wire the type which lays around here for wiring my potentiometer 0,125 or 0,25mm2
                100turns from middle to top and around 50turns back but same direction of winding
                core is a round ferrit 8mm dia lenght 70mm
                inductivity is higher then normal 20cm coil (normal is something around 300microH)
                tube coil has 600+
                by pushing and pulling the core i can change inductivity (and so the sens) rapidly
                core is moveable
                but when you only whant strongest settings you can adjust it with glue
                  hello satdaveuk
                  tube coil has 600+
                  core is moveable
                  Is that jumble wired or got to be evenly spaced like on most am radios
                    hello
                    wire is wound helical around the pvc pipe
                    every turn close to each other
                    some picture and ideas in this thread
                    http://www.geotech1.com/forums/showt...ght=coil+probe
