Whites V3i coil signal.
  • Whites V3i coil signal.
    Hi!
    I`m looking for shape of driving signal in Whites coil.
    I`ve seen some other Multi-frequency signals (if you have any - please post it too) but this time I`m specially interested in V3i signal.
    Also I would like to know what technique of receiving MF signal is used.
    Just one resonant circuit with extended bandwitch, or more complex thing ?
    Thanks!
    I dont think we can talk too detailed on here as it is a relatively modern kit and may still be in production..
    My guess is the 3 tones are generated in dsp and all feed a driver amp to coil
    The Rx splits anything received into 3 separately tuned Rx.
    I suspect the Tx and Rx coils are resonant at the lowest freq and the mid and Hi tones are odd harmonics of the lowest Tx freq so they resonate too.
    S
      The TX drive is a multi-period digital waveform. I think it was published in a short paper I wrote when the unit was introduced.
      On the RX side, the preamp is broadband and then the signal is split into 3 narrowband demod channels, much like any normal multiband radio.
