Help with Whites Treasuremaster VLF coil
  • Help with Whites Treasuremaster VLF coil
    Hi, I have obtained a damaged Whites Treasuremaster VLF/Disc metal detector. All the electronic components appear to be the originals and there is no damage to the pcb. However, the search coil is a different story as it has been opened by someone who for some reason or other has had the transmit coil removed. The receive coil is intact and the readings across it is a healthy 35 ohms. Is there anyone who knows what the length of the transmit coil should be for this particular model? It uses only the small 6.5" - 7" search head and the dimensions of the groove in the polystyrene bed where the windings laid are about 5". I gather this coil should have two middle tappings as there are four connections to be made from the receive coil. Any information would be much appreciated. I have tried to attach a picture of the coil casing but the "Manage Attachments" link here does not want to load my small jpg file???
