New hobby pi detector Coil
  • New hobby pi detector Coil
    Hello,
    Last week i bought this detector:
    http://newhobby.eu/PI-metal-detector-NH-126
    It comes with a 20cm coil for small objects, i like to build a 70cm round coil does someone knows which kind of wire thikness i need and how manny turns?
    Sadly the seller does not reply on this question.
    Best regards
    Stefan
    Originally posted by stefan-s View Post
    Hello,
    Best regards
    Stefan
    Given the lack of technical information on their website, it is not possible to determine the coil inductance and resistance required for this project.
    You will need to measure the inductance and resistance first, and then use the coil calculator -> Coil Calculator
      The standaard coil is 20cm 23 turns 0.6mm wire= 0.3mH
      As i can see in the schematic i think r1 or r2 (390) is the resistor for the coil.
        LOL My ears being half shot I would have to do SOMETHING with the Audio. That's EVIL .
          lack of technical information. this is Clone, this is Koschej 5I (5I with LEDs, 5IM with LCD), nothing new. there are always good guys who do a clone from a clone.
            R1 is the damping resistor, so that will most likely need adjustment for the new coil.
            For the 70cm diameter coil, the coil calculator gives the following for 0.66mm wire:
            10 turns = 265uH
            11 turns = 318uH
            12 turns = 376uH
            Personally, I would choose either 11 or 12 turns.
              10 turns = 265uH
              11 turns = 318uH
              12 turns = 376uH
              Great! Thanks i will try to build one tomorrow.
                http://www.metdet.ru/korsina2.htm
                  Yesterday i made a coil. 68cm with 16 turns of 0.50mm wire it works perfect, it ignored objects smaller than 5cm.
                  It takes a British WW2 helmet at 170cm in the ground.
                  Thanks so far.
                    Thanks so far.
                    I have one on order. can you tell me what the pots control ?
                      Pots control?
                      As far as I can see here, there are no potentiometers - http://newhobby.eu/PI-metal-detector-NH-126
                      This is very much like the Russian detector Clone Pi W. Instead of a IC TL074, 2xTL072 is placed.
                      S1 "Barrier-"/"Guard interval-"
                      S2 "Barrier+"/"Guard interval+"
                      S3 "Volume-"/"Up min-"
                      S4 "Volume+"/"Up min+"
                      S5 NC
                      S6 "Zero" (0)
                      S5 + S6 Set up
                      Read here in russian: http://fandy.hut2.ru/ClonePI_W.htm
                        guard interval is SAMPLE DELAY. russian guys use self-made terminology how they want.
                          GUARD INTERVAL.
                            You might be right, however i feel they just use bad translation software(same like certain chinese online trade sites ;-). Thanks for the links you post as well. The Кашчей cost much more in E-bay.
                            May i ask you whether there is a calculator for the basket type UTP coil as i would like to build bigger one? Russian language is not a problem for me. Thanks.
                              all calculators are in my disc in folder #coil_calculator_soft. all were checked by me and all are working.
                              but i do not know one for basket type. you have to wind more and measure L to value you want.
                              run on this link http://www.geotech1.com/forums/showt...baracuda/page2
