wet grass coil TGSL and auto oscillation
  • wet grass coil TGSL and auto oscillation
    HELLO, I return from a rally detection which proceeded in a wet grass field, I thus used my usual TGSL but there catastrophe, in spite of special wiring for wet grass the detector did not stop emitting false signals during at least 2 hours time that the wet grass does not dry, would have of another solution that the wiring of the mass to be able to attenuate this wet grass problem .
    sometimes another problem the detector is put to oscillate into full fields without reason connect it is put at paged, 2 or 3 beep a second it is there nothing to be understood.
