WANTED - quasar avr coil
  • WANTED - quasar avr coil
    Hello,
    Im working on quasar few month ago, and still confusing with the coil, im using ysdragon pcb and im not sure to put capacitor on Rx and Tx, without caps its working, after i put the resin, the coil is not work as before.
    If someone have 23cm DD coil template, industance value or another detail, that would help. Thanks
    you need to learn russian now... i know... that is bad issue for you, but russians are out of clear english.
    ask here http://www.md4u.ru/viewforum.php?f=9...2534187538a742
      If I hear that after the Resin the coil does not work anymore, I believe that the resin has move the Coils while hardening. If you are using polyester, the coil deforms when the resin becomes hard. The alignment of the coils (zeroing) is thereby lost. That is why polyester does not shed everything at once, but in layers.
        Russian, ukaraine, i have fisit, no data found.
        Tshe issue with resin hardening can be fix with thin wire or aluminium to get nulling again, i think
          no data found. you are ON SITE OF ANDY. this is HIS FORUM. he done this quasar and you would had have
          ask him.
