Over or under damping
  • Over or under damping
    I read on here somewhere about that its better to slightly over damped or under damped on the critical damping for a PI and I don’t remember which and can’t seam to be able to find it. Can anybody answer please, thanks.
    Slight underdamping can increase the sensitivity somewhat, but it can also result in instability.
      Thanks for the answer, but would make it unstable in what way if I may ask?
        Look at the drawing you posted again. There is clear answer (under-damped pulse oscillation)
          Ok thanks, damping would be unstable. I thought you meant it would make the detector unstable which in a sense it would.
            If you monitor the preamp output with an oscilloscope, and adjust the damping with the damping resistor tool, you can see the problem.
              good book to begin to read is ITMD.
              I nside T he M etal D etector. please read it first and then ask your question.
