The coil calculator asks for the wire diameter. I assume this is just the actual metal wire, and not the insulation right?
I think I read that it's better when there's more distance between windings? I assume that means that inductance is partly dependent on the distance between windings? The calculator doesn't ask about how thick the insulation is, or if the wire is single or multi-strand, or what type of metal the wire is.
I'm just trying to understand...do those things matter, or do they not matter enough to take into account? Or is the calculator just meant to give a rough estimate?
I guess I have a lot more reading to do - I'm still confused about the relationship between inductance and capacitance and all the other variables that I probably don't even know about yet! This stuff is definitely not easy, especially without an engineering backround!
