what number of wire to put for foul power to pirate?-clone pi, AVR. ? and -Delta pulse double side ?
  • what number of wire to put for foul power to pirate?-clone pi, AVR. ? and -Delta pulse double side ?
    hello all of you .what number of wire and turns, to put for foul power=at this detectors please . i have 0,5mm and 0,8mm coil wire i want to make my original Pirate max depth and stable. the machines are these 3.=pirate?-clone pi, AVR. ? and -Delta pulse double side ?
    How much turns Ohms - Mahanry-and turns please and fat no i got only 0,50 mm and 0,80 mm from engine mix, wire.
    You can use the Coil Calculator on this site.
      Id recomend 0.5 mm, for all coils. For Delta Pulse 470-500uH.
        Am făcut un detector de clonă pi-w și am făcut bobina conform acestui tabel. Poate va fi util. https://radioskot.ru/forum/14-2381-12 [COLOR = rgba (0, 0, 0, 0.54)]
        [/ COLOR]
        [/ COLOR ]
          [/ COLOR]
          [/ COLOR ]
          Also, the links to your images are broken. The correct procedure is to select Go Advanced, and then Manage Attachments.
            thankoy all of you my frends coil calculator seems very nice i dident openit yet , thankou Guys .
            for delta pulse this version from hear i have but i dont remember the user name , for this i have buy 350meters coil wire (emagie) 0.80 27x27 mono coil ,i hade 1,7 Ohms. with 85 turns .how much i have to conect and start arround the widing how many Ohms ? for the Delta?
              It depends on the coil size you're after and the machine you plan to use it on.
              I'd build a 40cm coil for the Delta Pulse for fist-sized targets at 1m max, if you want to go deeper, make a frame coil.
              Γνώμη μου είναι να φτιάξεις ένα 40άρι πηνίο για το Delta Pulse μιας και είναι το πιο δυνατό μηχάνημα από τα 3 που έχεις.
              Για 40άρι πηνίο θέλεις 20 σπείρες με 0.8mm καλώδιο για να φτάσεις τα 500uH, με αυτό το πηνίο μπορείς να χτυπήσεις έναν στόχο σε μέγεθος γροθιάς σε βάθος μέχρι ένα μέτρο.
              Αν έχεις μέση για να πας πιο βαθιά, μπορείς να φτιάξεις τελάρο 1Χ1 για καλύτερα αποτελέσματα.
                Σε ευχαριστω παρα πολυ.Πατριδα, το delta pulse εχει βαθος ,το ατοιμο 3ohms to 3,5ohms with a smaller search coil30x30 1,5 meters with o,7mm coil and with 0.8 coils cable inside i found i resistor at the coil input from the wires and my coil its bigger i dont remember how many ohms haves the coil head. και βρισκομαι αλου για ναμετρησω τα Ωμ. του αυτον τον δισκο πηρα παραδειγμα, αλα πρεπη να φοραη 0.7μμ καλωδιο προβλημα του εγω εμαθα οτι οσω πιο πολεσ σπυρεσ εχει τοσο πιο μεγαλο Παλμο στελνη σωστα τα λεω το τσεκαρα φιλε, τι να κανω μετο delta pulse? για πλεσιο, δεν ειμαι εχω μαθη ακομα και 1χ1 να το εχω υδραυλικες ταπες βιδοματος στοκονταρι, πολυ καλω για 50χ50 45χ45,τι λες? να παω να δω τα Ωμ ?και να τα γραψω αφαιροντας 1.3 Ωμ την αντισταση εισοδου που ειχε και εχει
                  Please write in English as per the forum rules.
                    DP has 16 turns for 1100x1100 frame coil. it is sure CLEAR draw on the schematic. i noticed much people are not able to see. blinded.
                    they look on schematic and see nothing.
                      that means 1.1m x 4 x 16 turns = 70.4 meters. So we need at least 71 meters of wire or more.. thank you so much
                        thankou very much . to all kt315 i have your version DP. i need for this a 40x40 curcule coil not frame coil i have only 0.80mm wire and o.50 iknow that ,the8mm i the corect
