DD-Flatcoil for IB/TR (and PI )
  • DD-Flatcoil for IB/TR (and PI )
    I would like to ask the coil specialists if it would make a sense constructing a DD-flatcoil (pancake-coil) for IB/TR (and maybe PI) detectors.
    Reason (my reflection): Making a larger coil (giving more search area and depth penetration) and getting more sensibility to small items as well.
    Shielding: Graphite spray or a copper based spray
    If it could make a sense, which would be the formulas applicable?
    HH & kind regards,
    Cyclops
    Works good on my PI
    Hi Cyclops,
    Flat wound is very good for minimal coupling, and great sensitivity.
    As expected I found I needed a couple more turns to equal the inductance of a bundle wound coil.
    Cheers
    Kev.
    http://www.findmall.com/cgi-bin/foru...y.pl?read=8378
      TNX for the link!!!
      Hi Kev,
      Thank you for the link.
      At least I know now that it is worth trying a little bit.
      Good to know that one needs some more turns.
      I did the inverse, with fewer turns and did not get any result on my IB300, that's why I posted the question.
      I will try with more turns now and post later when I have the next results.
      BTW, how did you adjust the coils? With a loose single turn that has been fixed later or have you found an other way? Which one?
      TNX again and HH,
      Cyclops
        Tuning
        Hi Cyclops,
        Because I made these for a PI there wasn't as much precision required, such as with a IB/VLF/TR type detector. I was looking to minimise the response from certain hot rocks in a given area so I adjusted the overlap to give the best response to small gold and least to the rock samples.
        Obviously there was a bit of a compromise, at the final point there was a slightly reduced resopnse to very small gold and conversely a little more from the rocks. I could have nulled the rocks completely at the exclusion of small gold.
        A bit long winded sorry. If you do a search on the PI Technology forum for balancing DD coils you should come across one Eric posted a while back, that used a 1khz oscillator and scope to find the point of least mutual inductance.
        Cheers
        Kev.
