Coplanar coil - newbie questions
  • Coplanar coil - newbie questions
    I read a US4293816 PDF-patent and I tried to build coplanar coil
    (RX - 88 turns, TX- 275 turns and bucking coil has 27 turns). Now I nave to tune it and have some newbie question abuot coplanar coils :
    -it is wrote in US4293816 that after nulling in RX coil the amplitude should be less than 6mV, but is not write notihg about ampliture which is given on TX coil.
    -the coils tuning with a capacitor on TX side is a must when I will tune coils not in resonanse frequency? Or I must tune coils in resonance frequency anf capacitor on TX side is a must?
    -The coils works in oscilating freq. to minimalize loss of energy, is thaht true?
    thanks for the help
    Michal
    It depends on your TX circuit. If the TX coil is part of a Colpitts oscillator, then the resonant frequency is largely determined by the coil inductance, and the tuning capacitor(s). At resonance, energy is mostly transferred between the coil & capacitor, except for ohmic losses. Peak amplitude is a little less than the supply voltage, so look at the patent to see what supply voltage they used.
