Coil Shell Info - Here you go Reg
  • Coil Shell Info - Here you go Reg
    Shell includes - shell with fitted scuff cover, flex fitting, nut, o-ring, nylon bolt with wing nut (1/4, 5/16, 8mm available).
    Note: Ears are not filled so that you can pour the ears with an epoxy resin capatible with your potting resin within the manufacturers prescribed time for best adhesion.
    All sizes are in inches...
    Concentric - 6, 9, 11, 12, 14, 16
    DD - 6, 9, 11, 12, 14, 16, 18, 20
    Elliptical (DD or Mono) - 4x6, 6x9, 8x12, 10x15, 12x18, 15x18, 16x20
    Mono - 6, 9, 11, 12, 14, 16
    Rectangular (DD or Mono) - 3x12, 4x16, 5x18
    Material - .060 thick ABS (before forming)
    Color - White or Black (white is better for beach/water hunting)
    Ears - .250x3 ID
    Ear Spacing - .900 / .750 / .720
    Cable Flex Fitting - Sealcon (includes fitting, nut, and o-ring) two sizes available to fit cable OD .11 to .26 and .16 to .31
    Shell molds are machined with 1/2 degree positive taper on the shell, 1/2 degree negative taper on the scuff cover e.g they have a slight dovetail fit.
    Pricing - Concentric, DD, Mono
    4-9 Inch $26
    10-12 Inch $28
    13-15 Inch $30
    16-20 Inch $34
    Pricing - Elliptical
    4x6, 6x9, 8x12 Inch $26
    10x15 Inch $30
    12x18, 15x18, 16x20 Inch $34
    Pricing - Rectangular
    3x12 Inch $26
    4x16, 5x18 Inch $28
    Hi Charles,
    Wow, you have been busy! Glad you posted the info. Hopefully, you will be picking up some orders.
    One question about the ears. I noticed you have 3 different widths or spacings. Which one fits the standard Whites shaft? I am assuming it is the narrow one. Also, I am assuming the larger size fits the Minelabs, so what does the third size fit?
    Thanks again for the info.
    Reg.
      Reg as you guessed the .900 ear spacing fits Minelab, .750 fits Whites and several other brands. I had one customer who wanted a slightly tighter fit hence the .720.
        Charles,
        Are you set up for Paypal? I'd like to order a 5x18. Feel free to copy your post to the Advertising section, maybe add some pics.
          Thanks Carl. See your private messages for the info.
          Reg if you are lurking, check your private email here on geotech.
          Charles
