Hy. I am building a DD coil for IB detector. The question is about the filling material. Usually in DIY projects epoxy is used, but it it both heavy and expensive. In ITMD it is suggested to use plastic paste dissolved in solvent or foam. Is there enough structural strength with these methods? (had instability issues due to movement before when making previous coil). What are your preferences and materials are used in commercial coil designs?
IB coil filling material
A hint on filling DD coil shells:
The coil NULL is very, very sensitive and the epoxy curing can move the coils resulting in the null going out.
Put some dams where the coils overlap and not fill completely with epoxy on first pour.
After epoxy cures did check/adjust null then put a few drops of epoxy to hold coils in place.
Check adjust before finial encasing with epoxy.
- Likes 1
