Tesoro Lobo Coil
  • Tesoro Lobo Coil
    Hi friends!
    Many of Tesoro coils has 20 degrees as the correct phase relationship for a DD coil, and 200 degrees for a concentric.
    But Lobo Coil is different or equal?
    I am asking because Lobo has about 1,35mH for TX and about 10mH for RX.
    Is there anyone has an original Lobo to check this relationship?​
    The TX-RX phase of any IB coil should be close to 0°. Or 180° if one of the coils is upside-down. The only deviation from this is due to the TX coil resistance. For a 1.35mH TX coil running at 19kHz you would need a coil resistance of 58Ω to achieve a 20° phase shift. More likely the shift is 1-2°.
      Hi Carl!
      Thank you for your reply.
      I am building this detector. About the DD coil, I don't have a replica of the form as the original. It is wider.
      I'm referring to the coil housing.
      But I think it will works the same, is it correct?
      Is there a reason why tesoro has used a narrow one?
        Different companies have used different shapes. Some people prefer elliptical DD coils, some people prefer round DD coils.
