Which Coil is Best
  • Which Coil is Best
    Which coil is best for PI, coplanar wound side by side, dual (windings lumped together) or mono or dual coil wound side by side....
    Depends on the design of the PI, and how you are using it. I suppose a truly balanced dual coil will offer the fastest potential sample time, if that's the goal. But it might not offer any advantages over a well-designed fast mono coil.
      Dear carl spiral dual coil is best or spiral mono is best, or monocoil windings lumped together is best. can I use a separate Rx coil separate the ground and connect to Lm318 in PI detector !!!!
