12 inch Ellipitical help please
  • 12 inch Ellipitical help please
    I have a Minelab Supersearch 12 inch ellipitical that I am trying to identify. Serial # is L590. It has a standard 5 pin plug. All I'm getting is R readings across some of the pins. No Inductance readings. Not sure if its a mono or DD.
    pins 1-2 4.70R
    pins 1-3 4.70R
    pins 2-3 .25R
    Any help would be appreciated as I have already contacted ML with no response.
    Plumabob in a mono pins 2,3 and 4 are linked and pins 1 and 5 are linked 1/5 are shield pin 4 is coax centre should read .4 to .6 ohms in DD pins 4 and 3 are linked pin 4 TX center pin 5 TX shield and pin 2 RX center and pin 1 shield hope this helps. Regards IBGold
      Thanks for answering me IBgold, but I'm confused as to what you are trying to explain to me. I do not understand what you mean by center. My connector has no center pin. Just 5 along the outside. I pulled the connector apart so that I can see the wires. This is what I have.
      1-green
      2-white
      3-twisted shield
      4-blue
      5-red
      Thanks!
        What I mean by centre is the coax centre conductor, For DD coax cable you have a RX centre conductor and a shield and a TX centre conductor and shield I am of coarse talking about coils for the SD/GP series of detectors I hope this solves the problem I could email the plug diagrams to you direct if that helps . Regards IBGold
          Mystery solved! It's a DD vlf coil for an xt17000, xt18000 or the eureka gold. Thanks again for the input!
            My above post is incorrect!
            This coil is for a GT16000, FT16000, Musketeer, Sterling and a few other older machines. It will not work on the 17000 18000 or Eureka gold!
