Magnum IB
  • Magnum IB
    I have done a Magnum 4 years ago
    Which type of coil will be good for this shematic to be stable
    can I use a DD coil
    That should be fine.
      How with a DD coil - but amplitude on Rx is verry low
        The coil that is on the magum diagram work fine too.
        For a DD you should find the right inductance so frequency is OK.
        Fred.
          Fred.
          Hi Fred
          Have you done a DD for magnum
            Yes i did, but it was too complicated to use and then i built the tesoro golden sabre, much simpler and excellent results.
            I have used the coil from magnum to the TGS,work OK.I will post later more results about coil for TGS.
            Fred.
              Fred.
              yesterday I made a DD for magnum it works better from magnum's coil
              but have a problem with indikator it is verry slowly
                Forgot to say, i have posted infor about DD results on the TGS thread.
                For your "indicator" i think to remember there was a capacitor for speed response.
                Fred.
                  Fred.
                  Thx fred maybe I must to add a other Oper Amplifier for the indikator I thnik - Amlitude is small
                    DD coil for Magnum
                    I will build experimental eliptical DD coil for Magnum (10x14") but I don't know how (about winding Rx coil - turns number, wire diameter and tuning). Can You help me?
                      for 26cm DD coils Tx is 70-72 turns diam=0.5-0.6mm2, Rx 150 turns diam=0.2-0.3mm2
                        DD coil for MAGNUM : D=27 , Tx 20cm,61n,0.28mm - Rx 20cm,61n,0.28mm
                        100% correctly.
