Set the ddcoil
  • Set the ddcoil
    How to set the ddcoil?
    I have built a ddcoil for the tesoro eldorado.
    To set I overlap it the two coils tx and rx so that to have the min signal, but if then I put in parallel a capacitor, the amplitude increases, etc.....
    Does someone know how to set it so that to have the max sensibility?
    thanks
    Re: Set the ddcoil
    You probably want to resonate the receive coil to the exact transmit frequency before you set the overlap, to maximize the signal level during the process.
      Re: Set the ddcoil
      Also I think that it needs to do so, but I have a doubt.
      with my eldorado if I put a capacitor from 10nF in parallel to the search head original tesoro, has the max signal, but the performances are the same!
      The stadium of entry of the eldorado perhaps needs a certain value of the wave well precise rx....
      I will make other tests.
      thanks Carl
