bandido coil
  • bandido coil
    can anybody tell me data of coil for bandido 2 Qmax? or maybe possible to use coils from other detectors? and what capassity of battery it uses
    i would be very thankfull!
    coil ...
    it is obsolete question. because was disscussed here some time ago.. the forum has stand UP then.
    give you ALL data I collected of. repeated especially for you
    XLT 9.5"
    TX: L=540uH R=1.4 ohms
    RX: L=36mH R=122.8 ohms
    Fisher 1210
    Rx 6,48mH / 15,3 Ohm
    Tx (1,64mH / 7,7Ohm) + (1,62mH / 7,5Ohm)
    Fisher 1266
    Rx 10-10,4mH / 38,2-39,3 Ohm
    Tx 2,14-2,2mH / 4,7-4,9 Ohm
    Fisher Quick Silver
    Rx 6,69-6,7mH / 31-32Ohm
    Tx 0,945-0,960mH / 3-3,1Ohm
    Winding, followed by pins (pos,neg), followed by inductance, and finally DC resistance.
    White's Spectrum
    Rx 1,2 36mH 123 ohms
    Tx 4,5 540uH 1.4 ohms
    White's 6B
    Rx 1,2 16mH 35 ohms
    Tx 4,5 1.7mH 7 ohms
    White's DFX concentric
    Rx 1,2 13.8mH 36 ohms
    Tx 4,5 540uH 2.7 ohms
    White's DFX DD
    Rx 1,2 14.2mH 55 ohms
    Tx 4,5 680uH 3.5 ohms
    Tesoro concentric
    Rx 3,4 6.2mH 22 ohms
    Tx 1,5 5.7mH 22 ohms
    Tesoro early Lobo DD
    Rx 1,3 1.35mH 12 ohms
    Tx 2,4 10mH 55 ohms
    Fisher CZ
    Rx 1,2 6.8mH 30 ohms
    Tx 3,4 1mH 2.8 ohms
    Most numbers are based on several coil measurements, including different size coils for a given coil type.
      Re: coil ...
      thanks, you gave really much info so now i have enough to build Bandido, thanks again
        Re: coil ...
        take these photos I done
        http://kt315.hotbox.ru/xlt_coil1.jpg
        http://kt315.hotbox.ru/xlt_coil2.jpg
        it will give a though how to build a coil. alhtough of Whites.
          Re: coil ...
          thanks again, i will build IB detector first, so all possible help would be very usefull for me, especially from you , i was looking on your "Wolksturm", but it looks a little bit complex for me, but i heard many good words about this project, so keep going so
            Re: coil ...
            you are welcome... I think you must keep a touch to this guy Rudi, link for you.
            http://www.thunting.com/cgi-bin/geotech/forum/view.cgi?action=message&forum=tech&message=2167
            Posted by Rudi
            Monday 02 December 2002, 13:11:34
            I would build the silver sabre.On 4 april this year BG post the circuit on this forum.Marcello post a circuit on 18 august of the silver sabre.Which one is the right one. Can i replace the LM2930 to 7805? Has anyone a pcb? Which coil? I found in a dutch book of metaldetectors : tx 100 turn of 0.5mm copperwire and a diameter of 200 mm and rx 170 turns of 0.5mm copperwire, diameter 80mm
