Sovereign Coil.
  • #46
    thanks. did you see these photos? it is Excalibur and a coil.
    http://photofile.ru/users/tutanhamon...279/120607726/
    [for ivconic - the photos are NOT MINE. I open coils without an hammer!]
    • #47
      Hi. This coil (BBS 1000) seems to be the same with the Tornado BBS 1000 that it used by the Sovereign
      • #48
        Awesome work Geo!
        Where did you get the housing?
        • #49
          Originally posted by mario View Post
          Awesome work Geo!
          Hi.
          Read some posts before....
          http://geotech1.com/forums/showpost....1&postcount=41
          http://www.mdushkov.hit.bg/
          • #50
            Hi.
            Are you the owner of the site???
            Oh, no These coils are produced, as you can see on the site, from 2002, or maybe earlier, don't know exactly I put this site here only for your information, because these coil housings are cheap - between 3-5 Euro in the SHOPS!!! But from some other producers they was offered
            more, more expensive in some forumsfor example russian
            • #51
              i do not know what you mean wrote russian. yes, i read feedback of Ciklon about these coil housings he got from anyone in Bulgaria... he critically wrote that they were done from thin plastic.
              • #52
                Thin? No, don't think so, but you have right about the criticism - maybe are made from reciclat
                • #53
                  Hello,
                  I measured around 400 mV at preamp output, can I consider my 8" excalibur coil well null balanced.
                  If not what can I do, I opened the coil, still functional, I can see the 8 shape small coil in serial wit Rx to null balanced and make all the measurement before the amp op
                  Thx
                  Philippe
                  • #54
                    If preamp has a gain near to 40 then the output of coil is about 10mV. It is not so good for a commercial coil , but if you see it from the other side... not so bad.
                    I don't think that you can do many things...
                    You can try to put a small coin on the coil and to move it left ... right.... etc. If you see a better null then glue it on the coil.
                    But i am not sure if it will work.
