AWG HELP
  • AWG HELP
    HI TO ALL
    IN THIS SCHEMATIC DETECT COIL WITH 0.31 AWG OR 0.31MM??????
    5 AWG = 4.6213mm
    6 AWG = 4.1154mm
    7 AWG = 3.6649mm
    8 AWG = 3.2636mm
    9 SWG = 2.9064mm
    10 AWG = 2.5882mm
    11 AWG = 2.3049mm
    12 AWG = 2.0525mm
    13 AWG = 1.8278mm
    14 AWG = 1.6277mm
    15 AWG = 1.4495mm
    16 AWG = 1.2908mm
    17 AWG = 1.1495mm
    18 AWG = 1.0237mm
    19 AWG = 0.9116mm
    20 AWG = 0.8118mm
    21 AWG = 0.7229mm
    22 AWG = 0.6438mm
    23 AWG = 0.5733mm
    24 AWG = 0.5106mm
    25 AWG = 0.4547mm
    26 AWG = 0.4049mm
    27 AWG = 0.3606mm
    28 AWG = 0.3211mm
    29 AWG = 0.2859mm
    30 AWG = 0.2546mm
    31 AWG = 0.2268mm
    32 AWG = 0.2019mm
    33 AWG = 0.1798mm
    34 AWG = 0.1601mm
    35 AWG = 0.1426mm
    36 AWG = 0.1270mm
    37 AWG = 0.1131mm
    38 AWG = 0.1007mm
    39 AWG = 0.0897mm
    40 AWG = 0.0799mm
    41 AWG = 0.0711mm
    42 AWG = 0.0633mm
    43 AWG = 0.0564mm
    44 AWG = 0.0502mm
    45 AWG = 0.0447mm
    46 AWG = 0.0398mm
    47 AWG = 0.0355mm
    48 AWG = 0.0316mm
    49 AWG = 0.0281mm
    50 AWG = 0.0251mm
    51 AWG = 0.0223mm
    52 AWG = 0.0199mm
    53 AWG = 0.0177mm
    54 AWG = 0.0158mm
    55 AWG = 0.0140mm
    56 AWG = 0.0125mm
    DEST WISHS
    0.31мм without varnish
      TANKS
      WHAT WHIT varnish????
        Originally posted by mesy64 View Post
        TANKS
        No problem with varnish.
          I have a wire dimensions chart that lists .315mm (bare) wire but does not list .31mm. If you cannot find the precise wire specified it is best to use the next larger size wire. Otherwise you may lose some signal output strength.
          So, if you cannot find .31mm wire you may want to use either .315mm or else use 28AWG which is .32mm. Since these numbers represent the bare wire diameter, the dimension of enameled wire would probably be about .35mm to .36mm, estimate for single thickness enamel.
          There is a very handy wire gauge chart here. It might not be complete but it is pretty darn close to it:
          http://www.allem.com/wireengr.html
          You want the "Magnet Wire Dimension Chart" although there is a another shorter chart that is also handy.
