Concentric PCB-Coil
  • Concentric PCB-Coil
    I am using a concentric PCB-Coil (ca. 20 cm diameter) and had phantastic measuring results:
    - very low temperature dependency
    - very thin dimension (ca. 3 mm)
    - very easy to build (just making a pcb-board)
    - no balancing needed (computer designed geometry - thus automatically balanced)
    - most of the area is for the rx-coil
    - combined small rx and big rx-coil (due to the geometry, the rx-coil is a spiral from the inner side to the outher side)
    - bigger transforming effect (nummer of turns for rx-coil is much more then for the tx-coils), to reduce the gain of the amplifier, thus reducing also noises of the amplifier.
    Therefore, it is very sensitive even to small metal objects (nuggets). To achive this, it was a very hard and long job.
    If you interested, may be I can put the pcb-board for the search coil here. Please ask me.
    I am now working an a new PCB-Coil, same size but lower inductance (tx-coils), bigger rx-coils, lower parasitric capacitance, single side pcb (the prior art was a double sided pcb-coil ;-) ).
    Aziz
    Re: Concentric PCB-Coil
    Hello Aziz, could you send me the drawings of the PCB coil please, because i´m plan to build one as yours ?
    thanks
    capela
      OK, I would like to see your pcb's.
      Thanks, Al.
        I cannot post the pcb-image.
        Its too big (700-800 k Gif-file).
        I get error message!
        I´m sorry.
        Aziz
          Hello Aziz, that is not too big my friend, if you use WinZip or WinRar, you can make it smaller, are using a 56Kmodem or ADSL ?
          Do you have another mail box ?
          thanks.
          Capela
            pcb coil
            hallo aziz
            my name is ludmil barosov.
            i am from bulgaria
            my e-mail is-dragon_name9@yahoo.com
            is it posible to send me shematic of your pcb coil?
            what program do you use to build this coil?
            i am using PROTEL for my pcb.
            can buil this coil on protel?
            best regards :barossov
            Aziz
              Aziz
              Hi, i have build the Clone PI MD and is woking fine, but i need to construct the best search coil for this machine. I m interested on coins. By now i can detect a 2 cms copper coing at 16 cms on free space.
              Any haelp will be appreciated
              In advance many thanks
              Nelson
              ce3llp@mi.cl
                Hello Aziz,
                Is this your coil? Wow..
                http://ibcoils.tripod.com/album/wien2.GIF
                  the photos were shared of a people (are not mine!!)
                  http://www.technoid.front.ru/photo/1.jpg
                  http://www.technoid.front.ru/photo/2.jpg
                  http://www.technoid.front.ru/photo/3.jpg
                  http://www.technoid.front.ru/photo/4.jpg
                  still one site on Clone PI
                  http://www.f-burn.ru/clonepi/index.html
                    Aziz
                    Tank you
                    bobsyn17@yahoo.com
