How to chose damping resistor (animation)
  • How to chose damping resistor (animation)
    I have been looking for this post for ages, and have just found it again
    its a nice little animation of how to chose the damping resistor.
    http://www.geotech1.com/forums/showp...&postcount=373
    brilliant idea, thanks for reposting
      Thank you 6666, i have see years ago this gif , very good for student ...this time i save it
        Hi All,
        One problemmo!, don't forget to preset the potentiometer or things get fried like a minelab GP3000.
        Ron
          Originally posted by authere View Post
          Hi All,
          Ron
          Good valid point
          would be better to put low value resistor in series with the pot just incase as a safety measure, then when measuring incl the both.
            Originally posted by satdaveuk View Post
            Good valid point
            I use a 10k pot with a series 270 ohm resistor, both in parallel with a 1k2 resistor, which provides an adjustment range between 220 ohms and 1k1. Then you don't end up frying the mosfet.
              hello
              where i have to connect scope probe on baracuda pi
              to measure damping range?
                Should be pin 6 of NE5534
                make sure the coil is away from all metal
                  thanks to australia
