musketeer x coil
  • musketeer x coil
    hello
    want to make a dd coil for a old minelab musketeer x
    based on minelab sterling
    i sold my musketeer to somebody seems that he has crushed the good white 20cm superscan coil
    next days i get the unit back and i want made a new dd coil
    parallel i will open the old one to see whats wrong
    has anyone tips for making dd coil musketeer x
    i read the the newer musketeer coils also fit to older ones
    has anyone some coil datas for me
    i measured the old one but i dont know the specs (some months ago since i tested)
    i think rx was something around 20mH and tx under 2mH
    alternativ i would buy a musketeer coil that fits but i cant pay more than 60Euro within shipping
    thanks for help
    Bernte, Found this in a post from Ivconic how to make a Musketeer coil for the IGSL
    Already known 255x137mm "D" form (for 27cm DD coil):
    - TX=1mH, 42 to 45 windings, wire 0.5 to 0.55mm
    - RX=14.7mH, 165 to 175 windings, wire 0.22 to 0.25mm
      hello kliner
      thats something i supposed
      because of igsl musketeer project but i´m not sure
      because of coil specs i measure from superscan musketeer coil (think isnide concentric)
      but if that are the datas i try my 4pin tesoro coils i have here
      or the 30*38cm sef coil for tesoro
      will see thanks
        http://www.geotech1.com/forums/showp...&postcount=975
        Hi Bernte-one
        I did a quick search on GT and hit this post it has some values you did a while back on your coil
          yes thanks
          but attention excellerator 2 coil doesnt work on musketeer and also not at igsl
          it has another phase shift ivconic gave me that info
          but yes you are right for dd musketeer i should use 1mH 14,7mH but i must look if i have the right cap values on tx and rx from musketeer it works with a lower frequency
