transistor woes please help
  • transistor woes please help
    Alternative's needed please if possible for common transistor's in uk thanks
    S9014 c331
    S9012 h331
    Im thinking bc547 for the s9014
    Stuck on the other one
    So can you help please also
    Looks like a reasonable replacement.....watch the basing diagram is different....reverse I think !! Easy to make a mistake here.....believe me.
    Don't you have any 2N**** devices over there??? Can you order from Digi Key or Jameco ??? Or maybe even
    this one....
    Flash
      These are general purpose NPN & PNP transistors. Just about anything should work, 2N3904 & 2N3906 in the US.
        Carl is correct, also can work BC548 & BC558 , these are general purpose complementary transistors.
          thanks guys I was looking and I figured general npn and pnp bipolar but then I thought no thats way to easy ive got a long way to go and a lot of things to learn
