Many thanks to you both for this information. I had pigeon holed my proven 2 stage amp project for the CHANCE PI because of difficulty in getting the direct transfer PCB method to work well enough. I will now pursue it further with these tips.
Hi Sinclair and Dan
I have also used the old type fax machine paper with quite good results Its the type that came in a roll
The freezer application makes the compound more solid and sticks better.
All the best
Dave
Hi
I use kemotransfer. Simplyer and got better result.
Take look here https://s5tech.net/viewtopic.php?f=95&t=4214
It is in Slovenian langue, but google translate is your friend...
why people with your english you so naive... you really can do perfect things and tell us more there but i noted you do not want raise up your mind from ground ((((((
