measuring the decay time of pi detector
  • measuring the decay time of pi detector
    dear all:
    i need measuring the duration of decay time of pulse of coil the pi machine. can any one help me and please if have schematic share it.(with high accuracy).
    thank's
    you mean without an o-scope?
      thank;s for reply
      yes,i want measure and readout without oscope.with analog meter or digital (lcd or 7-segment)
        then you have to build a detector on chipo that will show you the data on LCD.
          sorry,do you have advanced schematic for this issue?
            Originally posted by usefi5961 View Post
            dear all:
            thank's
            Lots and lots of info here is these forums.Green is one member doing a lot of decay measurements so Search for his posts and READ.
            There is NO way to measure this with a meter. One MUST measure many points during the decay then plot and calculate the decay which should follow this equation:
            V = Vo *e^(t/TC) as has been discussed many times in the forums here.
              guru,thank you very much for reply .i try to find answer in my question in forum.
              thank's
                That task is just one of those things that Really requires a O Scope to perform. Seriously , I can't think of any other means to measure duration of Time between two points of a signal without one.
                  You can do what Eric has done. Measure change in integrator out, target - no target with a voltmeter at different delay times(same sample time)and calculate. Delay times should be>one or two times the target TC.http://www.geotech1.com/forums/showt...869#post253869
                    LOL, THAT Sir is Above my abilities. LOL
