Geochemical Prospecting and Treasure Hunting
  • Geochemical Prospecting and Treasure Hunting
    Hi Folks,
    In light of your recent discussions I thought this
    information might be of interest to you!
    Action Mining Services in Las Vagas sell a Geochemical Meter and Instruction book for
    A bit over $100 U.S.
    Here's some information from the Instruction Book.
    Precious metals and Geochemicals are found together thoughout the world.
    Geochemicals exist in all mineralised hard rock
    veigns and placers.In this Manual when Geochemicals are mentioned we are referring to those minerals that have been or may be disolved in water.
    THE PRESENCE OF GEOCHEMICAL HALOES HAS BEEN KNOWN AND USED FOR 50 YEARS
    BY MANY MINING COMPANIES. Some modern
    mining companies have made the mistake of looking for acid soluable geochemicals.
    The acid soluable geochemicals exist everywhere
    and the water soluable geochemicals exist only
    around veins and deposits. Thus to use acid in the
    search can lead nowhere. Placer deposits all contain geochemicals and may be located by their presence.
    All mineralised areas have "Geochemical" haloes
    around them that have been produced by the
    wicking of the soluable minerals over the centuries.
    This halo often exists for hundreds of ft in every direction. from the mineralised vein and is easily
    detected with the "Geochemical" meter.
    Althgough there is no Gaurantee that precious
    metals exist within every mineralised vein,in gold
    country[Almost everywhere] that is where the precious metals are found and only there.
    Buried treasures also develop mineralised haloes
    around them that extend from 5 to 100 ft.
    The amount of time in the ground determines the
    extent of the halo.With Silver a halo can exist in 50 to 100 yrs. With precious metal a halo will exist after
    50 yrs or so,but precious metals is often buried in Metal Boxes or Boxes with iron nails or copper strips.
    These will all produce a halo in 30 yrs or less.A treasure 200 years old will produce quite a halo which in some cases can be detected up to 200 ft.
    The Meter can be used for many other things as well. Like testing rocks to see if they are worth
    getting assayed or not.
    If anyone is interested in finding out more "ACTION
    MINING" Ph NO.....[703] 362 1511
    Re: Geochemical Prospecting and Treasure Hunting
    Thanks Marsh,
    A great post. I know that Dr. Manuel Ortiz was big on Geochemical sampling. I don't don't know how long it takes to arrive at the cache by this method of searching once one is on the approximate cache area?
    Richard
    >Hi Folks,
      >Hi Folks,
      These will all produce a halo in 30 yrs or less.A treasure 200 years old will produce quite a halo which in some cases can be detected up to 200 ft.[/i]
      by what detection method ????
      no web page ???
        Since this statement appeared in conjuction with the Geochemical Meter, advertised by Action Mining, one would have to assume that the detection of such a 200 year-old treasure could be accomplished with the Geochemical Meter (and method).
        As with so many "well written" advertising blurbs, not only for this Geochemical Meter, but also many other products --the wording is purposely vague and non-distinct.
        For instance, "...A treasure 200 years old will produce quite a halo..."; does not define the size of the halo --it could be any size, and comply with this statement. We assume, by reading this, that it is big, but it doesn't have to be any bigger than a breadbox, or a tea-cup.
        And, "...which in some cases can be detected up to 200 ft..."; does not indicate that we WILL find the halo 200 feet from the target. It says, "up to 200 feet". The words "up to" were chosen carefully by the ad writer. If a treasure was 200 years buried, and the halo was only detectable at 3 feet from the target, this would comply with what was written in the ad just as well as if the halo was found 199 feet from the target.
        In my opinion, a field or halo of some sort, does occur around long-time buried targets and mineral deposits containing noble metals. (For that matter, less noble metals probably have a halo also, but of different characteristics.) However, I think VERY little real specifics are actually known about the characteristics of these fields. This I believe is due to the extremely wide variety of conditions around which these fields are formed, and the overall lack of field-measurable data that has been recorded about them at this time.
        This situation could change in the future, as more and more treasure hunter-scientists realize the value in utilizing and tracking these fields. Thus we might refine the information we know today, so that better instrumentation can be devised to track and record these fields and ultimately utilize these fields as an aid, instead of looking at them as a hindrance.
          perhaps my query was a little vague to some.
          to rephrase--what detection method does the geochemical meter rely on to produce an indication ???
          web site ?????
            >web site ?????
            Rick, the detection method is a chemical one that
            detects minerals by ppm (parts per million)It can
            even be used to sample water in creeks and rivers
            that are thought to contain minerals. The idea is to
            take samples to determine if the mineralization is
            increasing or decreasing from one location to the
            next. Think of the meter as a cheap type of
            spectrometer.I take exception to Scafferi bashing
            the claims of Mike Glenn, who is one of the most
            well thought of mining men in the business. I have
            known Mike for the seven years that I have been
            prospecting, and I completely trust his opinions. He
            is the builder of the Micron Mill Wave Table, and
            former Technical Editor of Popular Mining magazine.
              >web site ?????
                Hey, wait a minute, Bill. What "bashing" are you talking about? I've never heard of Mike Glenn, and have no preformed opinions of the man.
                I think chemical detection methods are no doubt as valid a way to zero in on long-time buried treasures, as anything else; --and probably a lot MORE valid than some of what we read on the LRL forums.
                In my post above, I was merely quoting the words in the ad, as Marsh had transcribed them. (I have to assume they were transcribed correctly.) I was not trying to cast any unfair aspersions on the validity of the product, or the method. I was merely pointing out that given the "wording" of the ad, it was a bit vague and open-ended, and left a lot of latitude for interpretation. I still maintain that opinion, and would defy anyone to read the ad, interpret the meaning of the phrases, and come to anything but the same conclusion.
                  thanks responce..
                  interesting approach--so perhaps more qualitive than
                  quantitive..is the techniqe specific or broad spectrum??
                    Bill: Scafferi (Carl too) is an expert at bashing and then pretending he didn't intend to, or the bashee simply did not understand his innocent intent. Be careful or Carl will ban you from his forum.
                      It appears that you may be the only one with a "problem" around here, and it seems you are doing everything possible to make a nuisance of yourself --just to see if YOU can get banned, I guess.
                      Keep it up.... it may just work for you. ;~)
                        Sam: Dell Winders says you have been bashing away at him almost four years and he doesn't understand why. I don't either. Why do you keep hammering at him? Anyone that comes on a LRL forum sooner or later tangles with you in a negative way and then you say it was just a misunderstanding and you are being "scientific"and they aren't. Why do you do this?
                          Re: Dan Peterson's Contribution??
                          A better question is:
                          What are you contributing, in the technical sense, with your recent flame bait postings??
                            There is an "Action Mining Services" in Oregon; is this the same company? They also have a web site, www.actionmining.com, but no mention of the meter.
                            I've written for info on the meter. Meanwhile, Marsh, do you have any further info on it? Do you own one, and if so, can you comment on how it works?
                              >- Carl
                              I have a 1997 Catalog from Action Mining, and it shows their address as Las Vegas, NV. Perhaps they have moved.
                              Anyway, on page 46 and 47 of this catalog, they describe the Geochemical Meter in some detail.
