Best scanner or radar
  • Best scanner or radar
    Hello all
    Im searching to find best scanner, radar or magnetometer, did you have an idea which is the best? exemple to see a brass of plate 30X30cm not more than 3 meter. Thank you in advance for your help
    (please do not suggest OKM products, I have already use their best products... no comment)
    > 30X30cm brass plate not more than 3 meter
    Well, 30X30cm @ 3 meter is impossible, even in air.
    You may get 2 meters depth with 50-150cm coil diameter.
    Magnetometer is not very good for brass or noble metals.
    If the soil is just very weak mineralized a Pulse Induction
    with 1m frame may work, if heavy mineralized you should
    go for the Jeohunter 3D and using the super big 1m coil.
    This machine has really very good ground elimination
    and can see through heavy mineralized soil or stones.
    But you need some experience first and the soil must
    have a minimum of the identical mineralisation level!
