Can I use FGM-1 for EPE Gradiometer ?
  • Can I use FGM-1 for EPE Gradiometer ?
    As I ask the topic, I have 2 FGM 1 sensor.
    My friend built EPE gradiometer for me.
    Can I use these 2 sensor for EPE gradiometer ?
    If yes, how I do it ?
    Thanks for your advance
    Yes.
    Connect it at gnd, +5V and give the output at clk1 and clk2.
    Or.. with other words connect it in the place of FGM3.
    Read datasheets first for pins!!!
      Yes.
      Thanks , I will try it..
      So what do you think about performance ?
      Do you have any idea between FGM1 and FGM3
        One is more sensitive than the other, but I forgot which. Pinout is the same.
          FGM3 is more sensitive bro..
          Im interesting how much percent different between FGM1 and FGM3 ?
            FGM1... This is a miniature version of the original standard FGM-3 type of sensor. It is essentially a three terminal device, (Gnd., +5 volts and Output) but a fourth terminal has been added which gives access to an internal over wound coil. This coil can be used to alter the zero field output frequency or as a feedback coil for linearity improvement. (see application notes). The output is in the form of a robust 5 volt rectangular pulse, whose period varies in proportion to the field along the principle axis of the device. Field Range + 0.5 oersted (+ 50 micro-tesla).
            FGM3....This is the original larger version of the sensor, (60 mm long x 15 mm diameter) which has a somewhat higher sensitivity making it more suitable in some applications where size is not important. It has the same type of output as the other devices. Field Range + 0.5 oersted ( + 70 micro-tesla).
              Thanks..
              I will try it
                hi to all masters can used fcl100 replic fgm3 ?
