Re: Lee Fraser, et al. - Re: Toroidal Coil Forms:
  • Re: Lee Fraser, et al. - Re: Toroidal Coil Forms:
    On Shielding:
    First we are discussing electrostatic shileding. Magnetic shielding
    would defeat the whole point of the exercise regardless of how it is
    applied (to the sensor that is, magnetic (and electrostatic)
    shielding of the amplifier can be useful.
    E/s shielding is done by surrounding the device to be protected with
    a conductive enclosure. Remember that with a toroid shaped sensor
    all of the action, so to speak, is within the toroid. There is
    essentially no external field therefore a shield can be used outside
    the toriod (including windings of course). If a conductor is used
    to construct the toriod form it will act like a shorted single turn
    in a transformer, causing high currents and heating with no
    effective magnetic field inside the toroid. Because the field of a
    solenoid exists outside the solenoid as well as inside shielding is
    more difficult because space must be allowed for this external
    field. By the way e/s shielding is very common on loop type antenna
    and metal detector sensors. These shields generally include an
    insulated or air gap to eliminate the shorted term.
    So in short be careful with shields and don't use a conductive form
    for winding toroids.
    While I'm here has anyone built a working magnetometer? I'm working
    on my third and believe me I've had everything go wrong. I am using
    a solenoid. I think a well wound and dimensioned solenoid is as
    good as a bad toroid anyday. I have been playing with J.A.
    Koehler's spreadsheet and have noted that it seems easier to get a
    little better signal strength with the solenoid. I agree that
    signal to noise ratio is important but as is pointed out if you have
    a decent signal most likely the SNR is OK. I also note that outside
    of device and thermal noise it's generally pretty quiet a few
    hundred feet "under the sea" (electrically anyway).
    While the sensor liquid is important it represents a means of
    possible enhancement or improvement. I know water works and it is
    well characterized. I also know that if I can get water to work
    then I should be able to get another proton source that is more
    stable and improves on water's characteristics.
    I think the low noise electronics associated with the front end are
    more difficult than the sensor and it is my experience that this is
    where all my bench time goes. The rest seems easier. By the way
    the front end should be shielded both electrostatically and
    magnetically. Noise at these low frequencies is very difficult to
    deal with.
    Has anyone attempted a cesium unit? I think I may put some effort
    into one for next season. This season is here and I'm going
    prospecting.
    Lee
