Re: INDEX TO THE FIRST 220 POSTINGS TO THIS FORUM
  • Re: INDEX TO THE FIRST 220 POSTINGS TO THIS FORUM
    By george i think you have something there Lee.
    You can reduce the rating of the contacts by using a relay to do the
    change over thing. But using a seperate switching element (ie power
    transistor with fly wheel diode) to apply the Polarisation current.
    I guess this adds the complexity of sequencing the switching and rewiring
    relay.
    Advantages could be that the reverse emf induced in the polarisation coil
    generated as the polarising field collapses is fed back to the battery
    (Assuming a battery with low enough internal resistance) so preventing
    arcing and extending battery life. (Not sure how much though). As
    switching contacts are not switching current they can be down rated.
    Disadvantages would be that due to the amount of time required for the
    sequencing. (Taking into account the time it takes for the polarising
    field to collapse via back emf into the battery)more of the precious time
    of precesion could be lost.
    This effectivly brings the discusion into a bit of a circle and leaves us
    looking at the proton rich fluid.
    Just thoughts
    Le Kirby
    Quoting Lee Fraser :
    > ------=_NextPart_001_002D_01BFBF25.0AC76C80
    > Content-Type: text/plain;
    > charset="Windows-1252"
    > Content-Transfer-Encoding: quoted-printable
    > The Proton Mag Forum
    > Where did everybody go?
    > =20
    > Dale, thank you very much for the great index. Now if I only knew
    > where =
    > to find the content...
    > http://www.geometrics.com/sci.html is the site where you can find
    > "Application Manual for Portable Magnetometers". Its in pdf and I
    > think =
    > about 1.7M. There's several other documents of interest here as
    > well. =
    > Look under literature on their home page. Some of it you will
    > have to =
    > order and some of it is available for download.
    > Here is a note I prepared that you might find interesting. Jim
    > Koehler, I'd be very interested in your view on bifilar windings.
    > __________________________________________________ ____________________
