Re: tests for magnetic materials
  • Re: tests for magnetic materials
    Hi Dale,
    Your question and one or two of the posts in answer seem to beg a bit of an
    explanation about magnetic fields in general, and units in particular. So
    if you are interested, bear with me.
    All magnetic fields result from (are manifestations of) movements of
    electric charge. This is true of solenoids, permanent magnets, or any other
    kind of magnetic device. In the case of a wire or solenoid, it is easy to
    visualize the flow of electrons and the resultant magnetic field. It gets a
    little more obscure with permanent magnets and magnetic core materials. But
    even there, relatively simple and workable understandings are possible
    without worrying too much about quantum mechanics and such. All materials
    are made of atoms, and all atoms contain moving electrons. These electron
    movements (electron spins, etc) are, of course, moving charges and therefore
    have an associated magnetic field, just like a single-turn solenoid. In
    most materials, these magnetic moments are randomly oriented in space (due
    to thermal random movements) and therefore the resultant external magnetic
    field is zero. And just as one energized solenoid exerts a force or torque
    on another nearby energized solenoid, these atomic-scale magnetic moments
    experience physical aligning forces and torques when an external magnetic
    field is applied to them. At this stage, it is useful to differentiate
    three different basic kinds of atomic magnetic moments. The kind that align
    themselves in parallel with an external field, but opposing that field (i.e.
    opposite polarity) are called "diamagnetic" materials. The kind that align
    themselves in parallel but adding to that field (i.e. same polarity) are
    called "paramagnetic" materials. Then there is a special kind of
    "paramagnetic" material which aligns not only with a strong external field,
    but even with the relatively weak neigbouring atomic-scale magnetic moments;
    these are called "ferromagnetic" materials. These "ferromagnetic" moments
    are rather like a military platoon on parade, whereas the "paramagnetic"
    moments are more like a crowd at a fairground (the applied field might be
    thought of, in this case, as a barker crying "free beer!"). So the
    resultant magnetic field of a structure comprising a winding and various
    magnetic materials nearby, is simply the summation of the little magnetic
    fields from an almost infinite number of little electric loop currents.
    These currents are all tending to line each other up, and fighting thermal
    activity tending to randomize that alignment.
    The above explanation also helps with problems in understanding magnetic
    fields with and without poles. A long bar magnet is easy to think of in
    terms of physical regions commonly called poles, and a long solenoid is
    completely analogous. A single-turn solenoid is not a large conceptual
    stretch from a multiturn solenoid, and as you "unwind" even that last turn,
    and get a short piece of wire, you realize that you are simply looking at a
    complete turn of larger radius (you cannot have an electric current without
    a complete turn, even if that turn passes through the battery or power
    supply). So now you can understand POLARITY as being, not the top or bottom
    region of a permanent magnet, but rather an indication of the direction of a
    resultant field (sort of like left-handedness vs right-handedness). The bar
    magnet is, after all, just the summation of billions of tiny atomic-scale
    electric currents or electron spins.
    Now I explained that these atomic-scale magnetic moments align themselves
    with external fields. When they do, the observed external field changes in
    magnitude as a result. When paramagnetic and ferromagnetic materials are
    introduced, the observed magnitude rises. When diamagnetic materials are
    introduced, the observed field magnitude decreases. The increase or
    decrease in observed field, as a fraction of the applied field, is called
    the "magnetic susceptibility". It is rather small (parts per million) for
    most materials, but can be very large (much larger than unity) for
    ferromagnetic materials.
    Above, I said that individual magnetic moments within a ferromagnetic
    material (like iron or nickel) will align even with only the applied field
    of neighbouring individual magnetic moments. These alignments, which I
    compared to military platoons on parade, can grow quite large, but their
    natural growth is limited by more subtle crystal-structure parameters that
    are more complex to explain. Suffice to say, that the growth of these
    magnetic equivalents to platoons on parade are called "magnetic domains".
    When an external field is applied, any such domains which are in
    near-alignment with that field tend to grow in size at the cost of
    neighbouring domains which are in poor alignment. Sort of like someone
    moving a fence between neighbouring properties. As the applied field
    becomes stronger, these domain boundaries (fences) move so far as to "meet"
    other boundaries coming in the opposite direction. As the applied field
    becomes stronger still, and the boundaries cannot move any further, the
    entire domain (that is, the physical crystal structure itself) moves into
    alignment with the applied field. If you listen carefully near a
    magnetically energized piece of ferromagnetic material, you can actually
    hear the sound waves produced by this movement (it is called Barkhausen
    noise). The hum from a power transformer is largely caused by this effect.
    The magnetic field of the earth is quite similar to the above. It is
    produced by large convection currents in the earth's molten core (due to
    thermal gradients produced by nuclear reactions in the earth's core). These
    convection currents carry electric charges and cause magnetic fields. The
    magnetic field is not that of a simple solenoid, but multiple complex loops
    with a strong tendency to align close to the earth's axis of rotation.
    There is thought to be a self-energized dynamo action which produces the
    resultant field, and the field has been well characterized in terms of its
    distribution in space and its change in time. The time rate-of-change is
    really very considerable (just compare a magnetic map from 1900 or 1950 with
    one from today).
    Now for units. Think of a single loop of electric current as being a
    magnetic "force". This force or field strength is expressed in
    amperes/meter (or oersteds in the old cgs system). This magnetic force in a
    magnetic circuit is analogous to electric potential (in volts) in an
    electric circuit. If this magnetic force exists in free space, there
    results a magnetic "flux" (expressed in webers) which is analogous to the
    electric current (in amperes) in the electric circuit analogy. There is a
    related parameter called "flux density" (expressed in webers/square meter,
    also called a tesla; the old cgs unit was the gauss) which is equivalent to
    current density (amperes/square meter) in the electric circuit. In that
    electric circuit, the ratio between potential (volts) and current (amperes)
    is resistance (ohms). In the magnetic circuit analogy, the equivalent of
    resistance is called "permeability", and its value in free space (the
    "permeability of free space" is 4*pi*10E-7). This permeability is
    determined directly by the "susceptibility" of the materials within the
    region of interest.
    Lastly, in direct answer to your question about measuring susceptibility, it
    can be measured by observing the change in inductance of a solenoid placed
    around the material in question. If that solenoid is incorporated into a
    resonant circuit (electronics jargon here) you can note with even
    inexpensive equipment that there is a measurable phase shift (the angle
    between alternating voltage and current) as the susceptibility changes, even
    by parts per million. The phase-change observations can be done with
    bridge-like (nulling) circuits.
    Your bit of ferromagnetic material in the center of your wire would be
    magnetized according to the applied field at that point. In the absence of
    other turns of wire nearby, the field would form a loop centered about the
    axis of the wire, and the domains in the magnetic particle would therefore
    align in a circular array. This would minimize, but not eliminate, external
    observable field change. In a long solenoid, the magnetic field is not
    symmetric around each turn of wire, as you can easily prove for yourself by
    just tracing the resultant magnetic loops from several nearby turns of the
    solenoid.
    I hope some of this helps.
    Best regards,
    Peter Boetzkes
    ----Original Message Follows----
    Reply-To: "The Proton Mag Forum"
    Subject: Re: tests for magnetic materials
    Date: Fri, 16 Jun 2000 02:00:15 -0600
    Many thanks to Cris, Peter and George for the valued input.
    Some of it quite a bit above my head but I feel I have already
    learned something and hope to learn more if you are kind
    enough to answer this posting.
    Cris: I did not quite understand if the Neodymium "Super Mag"
    is a magnetometer, gaussmeter, metal detector or what. Also
    not clear if it is the same thing that sells for 99 Quid. I
    can afford that amount so if it is simple enough that there is
    a reading and a big reading is bad and a small reading is good
    (or vice versa), I want one and would appreciate knowing where
    I can get product literature and order one as I could find no
    reference on the web.
    I keep coming back to the "hand held digitial gaussmeter shown
    at
    http:www.ascscientific/gauss.html
    and it seems to me that this or something similar would
    work??? (Does anyone know why this web address does NOT
    highlight and the one below DOES highlight???
    Peter: The only item that I know of that shows it is
    specifically to measure the "magnetic susceptibility" of
    something is a rather pricey item (I think US$2000.00 or so)
    made in Australia and found at
    http://www.geoinstruments.com.au/main.html. I also know
    TerraPlus and some other firms have them but I think price
    even greater than that shown above.
    At the risk (or probably certainty) of sounding really
    stupid - is a "magnetic suceptibility meter" the same as a
    "gaussmeter"???
    George: Your method sounds like the most exciting of the
    bunch, but considering the knowledge base that I am starting
    from and the fact that I am the only man in the world who has
    frittered away six months and haven't even selected my
    toroidal form yet, if I got started on your project, I'd be
    six feet (1.82880 metres) under before I finished. I am not
    depreciating or denigrating your greatly appreciated answer -
    only trying to interject a bit of humor into MY own personal
    failings. Or possibly "LMF".
    Again thanks and very best regards to all,
    Dale
    PS I regret boring you with these things you all know so well
    but I just can't seem to learn it from books. In fact for
    whatever reason I cannot even read a full page in a technical
    book anymore without my mind wandering so bad that I start
    the same page five times before I give up.
    ----- Original Message -----
    Sent: Thursday, June 15, 2000 11:40 AM
    > Mag forum,
    > Another angle:
    > Am late on this discussion as I have been maggin in
    Mocambique
    > and have returned without malaria, cholera or yellow fever.
    > I have wound a number of coils mostly solenoids and found a
    > simple test for magnetic buildup which may be useful, as
    follows:
    > In the field, a magnetized solenoid will show a deviation if
    swung
    > from E-W to W-E, at worst up to 5 nT . Couldnt find any
    effect
    > of ferrous contaminated Cu wire and assumed it would cancel
    > itself out within the wire**. Did get deviations when
    mag probes
    > were rubbing against anchor chain in the bilges of the boat
    or
    > dragged across a warehouse floor or deck of a steel survey
    vessel.
    > The test system I used was a hollow solenoid into which a
    bottle
    > could be placed for testing the various fluids and over
    which a
    > PVC housing with various plastics could be tested . Ran it
    > overnight at 2 A from 24v DC to get some serious
    polarization and
    > tested it in the field on top of a 3 Metre wooden pole
    which could
    > be rotated and the trace observed. Using a notebook and a
    > PICOSCOPE oscilloscope a number of measurements of various
    > type s could be obtained
    > . After that one can use the least offensive of the
    various
    > materials from the same stocks to build the final toroid
    etc.
    > I like the idea of bifilar windings but always think of the
    field
    > situation like what cable to use and where the earth will
    be .
    > Cable is always a problem and stray voltages on a boat can
    realy
    > become a character -building experience. In addition
    ,cables can
    > be microphonic and change capacitance (pF) with wave
    action ...
    > George
    > **PS Quiz: a ferrous particle in the very centre of a
    current
    > carrying copper wire will become polarized in which
    direction?
    __________________________________________________ ____________
    ________
