PROTON RICH LIQUIDS - A LIST OF POSSIBILITIES
  • PROTON RICH LIQUIDS - A LIST OF POSSIBILITIES
    Following is a list of proton rich fluids I have looked at. I
    strongly urge that you
    double check my figures if you decide to try any of them. The
    number in brackets { } is MY
    rating system and any relationship to a scientific rating system is
    purely coincidental.
    Input on ANYTHING related to this list would be GREATLY appreciated.
    Do not pay too much
    attention to any prices shown because in most cases they are the
    best laboratory grade that
    is available. For example laboratory grade Kerosene is like US$30 -
    35 per gallon and just plain
    old Kerosene must be US$2.00 or less for a gallon. In many (not
    all) a grade less than laboratory
    grade will probably do fine.
    Amyl Alcohol (Pentyl Alcohol) {4.99}
    Formula: CH3 (CH2)3 CH2 OH
    Mol. Wt.: 88.1492
    #H Atoms: 12
    Density: 815
    Chi:H2 O: .998
    Flash: 32 C (89 F)
    Melt: -79 C (-110 F)
    Boil: 101 C (213 F)
    Auto-Ig: 300 C (572 F)
    Cost: $220.40 for 4 liters.
    CAS#: 71-41-0
    Stable: Yes
    A colorless liquid used as an artificial flavoring. Anything in the
    Amyl Alcohol family is
    flammable, produces toxic gas and is hygroscopic. Said to be
    slightly soluble in water ac-
    cepting 1 - 5 g/100ml at 17 C. It is soluble in alcohol, ether,
    benzene, chloroform, glyc-
    erol and oil. Vapors are heavier than air and may travel a
    considerable distance to a
    source of ignition and flash back to origin. It can be used with:
    glass, PVC (Type 1),
    Teflon, nylon, polypropylene or neoprene. It should NOT be used
    with tygon, polyethylene,
    viton, silicone or santoprene.
    Benzene {1.212}
    Formula: C6 H6
    Mol. Wt.: 78.11
    #H Atoms: 6
    Density: 876.5
    Chi:H2 O: .606
    Flash: -11 C (12 F)
    Melt: 5.5 C (42 F)
    Boil: 80.1 C (176 F)
    Auto-Ig: 497 C (928 F)
    Cost:
    CAS#: 71-43-2
    Stable:
    Vis: .65 x 10 -three
    Benzene is colorless, flammable and toxic. Use only with Teflon,
    nylon, urethane or viton.
    It performs poorly with LDPE, polycarbonates, PVC and polystyrene.
    Benzyl Alcohol Chi .690
    1-Butanol (Butyl Alcohol/n-Butanol) {4.915}
    Formula: CH3 (CH2)2 CH2 OH
    Mol. Wt.: 74.12
    #H Atoms: 10
    Density: 810
    Chi:H2 O: .983
    Flash: 35 C (95 F)
    Melt: -89 C (-128 F)
    Boil: 117.6 C (243 F)
    Auto-Ig: 343 C (649 F)
    Cost: $45.00 per Liter.
    CAS#: 35296-72-1
    A clear, colorless solution with a strong characteristic alcoholic
    odor. Class 3 severely
    flammable rating. Vapors can flow along surfaces to a distant
    ignition source and flash
    back. Sensitive to static discharge. Store in a cool, dry, well
    ventilated location, away
    from any area where fire hazard may be acute. Stable under ordinary
    conditions of use and
    storage. When released into the soil the material is expected to be
    readily biodegradable
    but this material is expected to leach into groundwater. Can be
    used with LDPE, HDPE, PP,
    polycarbonate and polystyrene.
    1-Butanol (Tertiary Butanol has similar characteristics.)
    2-Butanol (Sec Butyl Alcohol) C4 H10 O has similar characteristics
    but melts at -115 C
    and boils at 99.5 C. The various butanols can be used with glass or
    Teflon.
    Decahydronaphthalene (Decalin/Dekalin) {6.3}
    Formula: C10 H18
    Mol. Wt.: 138.25
    #H Atoms: 18
    Density: 896
    Chi:H2 O: 1.05
    Flash: 57 C (137 F)
    Melt: -31 C (-22 F)
    Boil: 187 C (368 F)
    Auto-Ig: 250 C (482 F)
    Cost: $124.50 for 2.5 Liters.
    CAS#: 91-17-8
    Clear to colorless, combustible liquid that is hygroscopic and which
    has a mild hydrocarbon
    odor. Insoluble in water. Stable under normal temperatures and
    pressures but sensitive to
    air. Reacts violently with strong oxidizing agents. Heat and light,
    particularly direct
    sunlight, could cause it to form explosive peroxides. Addition of
    water or other appropri-
    ate reducing materials will lessen peroxide formation. Class 3
    hazardous material which is
    volatile on contact with steam. Store under nitrogen and do not
    pressurize. Very soluble
    in acetone, alcohol, benzene, esters and most ketones. Miscible
    with propyl and isopropyl
    alcohols.
    Decane (n-Decane; decyl hydride; alkane C10) {5.08}
    Formula: C10 H22
    Mol. Wt.: 142.2838
    #H Atoms: 22
    Density: 730
    Chi:H2 O: 1.016
    Flash: 46 C (114 F)
    Melt: -29.7 C (-21 F)
    Boil: 174.1 C (345 F)
    Auto-Ig: 210 C (410 F)
    Cost: I believe prohibitively expensive.
    CAS#: 124-18-5
    A clear colorless, hydrophobic liquid. Can be used with PVC but
    possibly there are other
    materials that are also usable.
    Decanol (Decyl Alcohol) {5.16}
    Formula: CH3 (CH2)8 CH2 OH
    Mol. Wt.: 158.29
    #H Atoms: 22
    Density: 825 Check as some show range of 829 - 831
    Chi:H2 O: 1.032
    Flash: 82 C (180 F)
    Melt: 6 C (43 F)
    Boil: 230 C (446 F)
    Auto-Ig: 288 C (550 F)
    Cost: $38.40 for 500 mL.
    CAS#: 112-30-1
    Colorless to light yellow, hydrophobic, viscous, refractive liquid
    with odor of oranges.
    Insoluble in water and readily biodegradable. Stable under ordinary
    storage. Incompatible with strong oxidizing agents, inorganic
    acids, aledhydes, monomers
    and polymerizable esters, alkylene oxides, halogens and acid
    anhydrides. Class 2 flammable
    substance. Store in a cool, dry, well-ventilated location, away
    2-Decanol {3.096}
    Formula: C10 H22 O
    Mol. Wt.: 158.28
    #H Atoms: 22
    Density: 825
    Chi:H2 O: 1.032
    Flash: 85 C (185 F)
    Melt: -5 C (23 F)
    Boil: 211 C (411 F)
    Auto-Ig:
    Cost: Probably VERY expensive.
    CAS#: 1120-06-5
    Clear, colorless, combustible liquid. Stable under normal
    temperatures and pressures.
    2-Decanol is one of the alcohols which is least soluble in water as
    the long alkyl chain
    (10 Carbons) would actually repel the single -OH group of the water.
    Probably can hydrogen
    bond with other alcohol molecules.
    Decene (1-Decene) {4.75}
    Formula: C10 H20
    Mol. Wt.: 140.268
    #H Atoms: 20
    Density: 741
    Chi:H2 O: .950
    Flash: 47 C (116 F)
    Melt: -66 C (-86 F)
    Boil: 166 C (330 F)
    Auto-Ig: 235 C ( 455 F)
    Cost: 35.50 for 1 Liter.
    CAS#: 872-05-09
    Stable: Yes
    Colorless, flammable, hydrophobic liquid.
    Diacetone Alcohol (4-Hydroxy-4-Methyl-2-Pentanone) Chi .874
    Diesel Fuels and bunkering fuels contain hydrocarbons with higher
    numbers of carbon atoms
    and higher boiling points. Can be used with viton.
    Diethylene Glycol Chi
    3,3-Diethylpentane {4.232}
    Formula: C9 H20
    Mol. Wt.: 128.257
    #H Atoms: 20
    Density: 754
    Chi:H2 O: 1.058
    Flash:
    Melt: -33 C (-27 F)
    Boil: 146 C (294 F)
    Auto-Ig:
    Cost: Probably very expensive.
    CAS#: 1067-20-5
    Stable: But probably forms dangerous peroxides if exposed to air
    for too long a time.
    Dipropylene Glycol (Oxybispropanol) {2.87}
    Formula: C6 H14 O3
    Mol. Wt.: 134.1748
    #H Atoms: 14
    Density: 1020
    Chi:H2 O: .957
    Flash: 138 C (280 F)
    Melt: -40 C (-40 F)
    Boil: 229 C (442 F)
    Auto-Ig:
    Cost: Might be expensive.
    1-Dodecene {5.832}
    Formula: C12 H24
    Mol. Wt.: 168.3216
    #H Atoms: 24
    Density: 758
    Chi:H2 O: .972
    Flash: 77 C (170 F)
    Melt: -35 C (-25 F)
    Boil: 213 C (415 F)
    Auto-Ig: 255 C (491 F)
    Cost: $45.10 for 500 ml.
    CAS#:112-41-4
    Stable: Yes
    Ethyl Alcohol (Ethanol) {2.775}
    Formula: CH3 CH2 OH
    Mol. Wt.: 46.07
    #H Atoms: 6
    Density: 789.3
    Chi:H2 O: .925
    Flash: 12 C (55 F)
    Melt: -114 C (-173 F)
    Boil: 78.5 C (173 F)
    Auto-Ig: 362 C (685 F)
    Cost: $84.20 for 4 Liters.
    CAS#: 64-17-5
    Stable:
    Vis: 1.20 x 10 -3
    A volatile, flammable, colorless liquid having a pleasant odor and
    miscible in water and
    many organic solvents. Can be used with Mylar, LDPE, HDPE, PP,
    polymethylpentene,
    polycarbonate, PVC and polystyrene.
    Ethylene Glycol {4.85}
    Formula: HO CH2 CH2 OH
    Mol. Wt.: 62.07
    #H Atoms: 6
    Density: 1115.0
    Chi:H2 O: .970
    Flash: 111 C (242 F)
    Melt: -13 C (8.6 F)
    Boil: 195 C (383 F)
    Auto-Ig: 398 C (748 F)
    Cost: $103.50 for 3 Liters.
    CAS#: 107-21-1
    Stable: Yes
    Hydrophilic liquid which is miscible in water. Can used with epoxy
    or PP. May form explo-
    sive peroxides if exposed to air for extended periods.
    EZ-1000 Compressor Lubricant
    Formula: C10n H20n +2
    Mol. Wt.:
    #H Atoms: 20?
    Density: .79 to .85
    Chi:H2 O: 1.001 GUESS GUESS
    Flash: 325 - 550 F
    Melt:
    Boil: >300 F
    Auto-Ig:
    Cost: $37.55 per gallon.
    From Undersea Breathing Systems, 3599 23rd. Avenue S, Lake Worth, FL
    33461
    (http://www.dnax.com). This is a Polyalphaolefin (Hydrocracked
    Hydrocarbon) of the syn-
    thetic petroleum hydrocarbon family. It is a clear liquid with a
    light yellow to light
    brown tint and is non-hazardous. It is stable, insoluble in water,
    and has unlimited shelf
    life if in original container. It is the only compressor fluid that
    meets FDA guidelines
    for food grade additives.
    Fuel Oil #2
    Flash point varies from 126 degrees F to 204 degrees F. Auto
    ignition temperature is 494
    F. A light brown combustible, straight run or cracked petroleum
    distillate consisting
    mostly of C9 to C23 range hydrocarbons. Fuel oil is neither
    volatile nor likely to form
    emissions and is relatively non-persistant in the environment.
    Stable. Can be used with
    PP, polycarbonate or PVC.
    Gasoline provides a lower signal and longer delay. Other than the
    fire hazard it also
    eats the insulation on the copper windings. Gasolines are mixtures
    of hydrocarbons with 4
    to 12 carbon atoms and have boiling points between 30 and 210
    degrees Celsius. It can be
    used with epoxy, Teflon, nylon, urethane or viton.
    Glycerine (Glycerol) {3.944}
    Formula: CH2 OH CH OH CH2 OH
    Mol. Wt.: 92.09
    #H Atoms: 8
    Density: 1261.0
    Chi:H2 O: .986
    Flash: 160 C (320 F)
    Melt: 17.8 C (64 F)
    Boil: 290 C (554 F)
    Cost:
    CAS#:
    Auto-Ig: 370 C (698 F)
    Stable: Yes
    Vis: 1490 x 10 -three
    A colorless, odorless, sweet tasting, syrupy liquid which is
    hygroscopic. Can be used with
    PVC, LDPE, HDPE, PP, polymethylpentene, polycarbonate, polystyrene,
    Teflon, nylon, polypro-
    pylene, viton, neoprene or santoprene.
    Heptane 98% minimum {4.915}
    Formula: CH3 (CH2)5 CH3
    Mol. Wt.: 100.21
    #H Atoms: 16
    Density: 684.0
    Chi:H2 O: .983
    Flash: -4 C (25 F)
    Melt: -90.6 C (-131 F)
    Boil: 90 C (194 F)
    Auto-Ig: 222 C (433 F)
    Cost: $36.40 for 500 ml.
    CAS#: 142-82-5
    Stable:
    Can be used with glass, PVC(Type 1), Teflon, polycarbonate, nylon,
    or viton.
    n-Hexanol {6.024}
    Formula: CH3 (CH2)5 OH
    Mol. Wt.: 102.76
    #H Atoms: 14
    Density: 819
    Chi:H2 O: 1.004
    Flash: 60 C (140 F)
    Melt: -52 C (-61 F)
    Boil: 156 C (312 F)
    Auto-Ig: 292 C (559 F)
    Cost: $46.79 for 500 ml.
    CAS#: 111-27-3
    Colorless liquid, slightly soluble in water.
    Iso-Butyl Alcohol (2-Methyl-1-Propanol) {2.92}
    Formula: (CH3)2 CHCH2 OH
    Mol. Wt.: 74.12
    #H Atoms: 10
    Density: 802.0
    Chi:H2 O: .973
    Flash: 28 C (82 F)
    Melt: -108 C (-162 F)
    Boil: 108 C (226 F)
    Auto-Ig: 415 C (779 F)
    Cost: $38.00 for 500 ml.
    CAS#: 78-83-1
    Stable: Yes
    Can be used with LDPE, HDPE, PP, polymethylpentene, polycarbonate,
    or PVC.
    IsoAmyl Alcohol (Isopentyl Alcohol) {4.955}
    Formula: C5 H12 O
    Mol. Wt.: 88.1492
    #H Atoms: 12
    Density: 809
    Chi:H2 O: .991
    Flash: 43 C (109 F)
    Melt: - 117 C (-178 F)
    Boil: 130 C (266 F)
    Cost: 55.00 for 500 mL.
    CAS#: 123-51-3
    Auto-Ig: 350 C (662 F)
    Stable: Yes
    A colorless liquid with an alcoholic odor which causes coughing,
    used for artificial fla-
    voring A form of Pentanol. Soluble in water.
    Isopropanol (2-Propanol/Isopropyl Alcohol) {2.82}
    Formula: CH3 CH OH CH3
    Mol. Wt.: 60.10
    #H Atoms: 8
    Density: 785.0
    Chi:H2 O: .940
    Flash: 12 C (54 F)
    Melt: -88.5 C (-126 F)
    Boil: 82.4 C (180 F)
    Auto-Ig: 399 C (750 F)
    Cost: $47.00 for 1 Liter.
    CAS#: 67-63-0
    A colorless, flammable liquid with a pleasant odor, which is
    miscible in water, ether and
    alcohol. Can be used with epoxy, LDPE, HDPE, PP, polymethylpentene,
    polycarbonate, PVC or
    polystyrene.
    Jet Fuel can be used with glass, PVC, Teflon, nylon, urethane or
    viton. JP-A, JP-A1 and
    JP-8 have flash points of 100 - 129 F and are Class II flammable
    liquids and can be used in
    place of kerosene in heaters, etc. JP-4 has a flash point of less
    than 29 F and is a Class
    I flammable liquid. Kerosenes used in jet fuel contain hydrocarbons
    with 10 to 16 carbon
    atoms and have boiling points between 150 and 240 degrees Celsius.
    Kerosene (#1 Fuel Oil) {5.0}
    Formula: C9 - C19 H?
    Mol. Wt.:
    #H Atoms:
    Density: 800
    Chi:H2 O: 1.001 - 1.031?
    Flash: 38 C (100 F)
    Melt:
    Boil: 175 C (347 F)
    Cost: $36.00 for 1 gallon.
    CAS#: 8008-20-6
    Stable: Yes
    A straight run petroleum distillate liquid having a characteristic
    odor, miscible in petro-
    leum solvents and immiscible in water. Oily, stable, and
    combustible with pale yellow to
    water white color. Kerosene provides a higher signal, but a quicker
    decay time. Density
    810.0. Depending on manufacturer, flash points range from 100 F (38
    C to 160 F (71 C).
    Can be used with glass, PVC, polycarbonate, Teflon, nylon urethane
    or viton. In the old
    encyclopedia at work it shows a flash point of 150 C but this may be
    for "paraffin oil"
    which is considered by some to be kerosene and additionally is the
    name used for Kerosene
    in the UK. The general formula for Kerosene is Cn H2n +1 where "n"
    usually ranges from 12
    to 16.
    "...but the typical 'n' value for Cn H2n is 14 for kerosene, so the
    general formula is C14
    H28. Some kerosenes contain more alkane, so the average MW formula
    is C14 H29 since it is
    a mixture of C14 H28 and C14 H30."
    Therefore we have the following possible calculations for Chi in
    relation to H2 O.
    1. C14 H28 with a molecular weight of 196.372 and an assumed
    density of 780: Chi = 1.001.
    2. C14 H29 with a molecular weight of 197.380 and an assumed
    density of 780: Chi = 1.031.
    3. C14 H30 with a molecular weight of 198.388 and a density of 763:
    Chi = 1.038.
    Alpha 100% 90% .78 160 F 70829 8008-20-6
    Fisher 100% .826 350 F 8012-95-1
    Farmland >95% 0.8 125 F 6G072 8008-20-6
    Priestly 94% 160 F 450 91-20-3
    Spectrum 99% 0.8 100 F 410 F 63415 8008-20-6
    Priestly product is principally naphthalene (SARA III)
    Fisher Product is mineral oil and is soluble in benzene, ether,
    chloroform, carbon
    disulfide, petroleum ether and oils. It is insoluble in alcohols
    and presumably insoluble
    in water. This can be used to reduce the flash point of Kerosene
    maybe.
    Methanol (Methyl Alcohol) {2.67}
    Formula: CH3 OH
    Mol. Wt.: 32.04
    #H Atoms: 4
    Density: 791.4
    Chi:H2 O: .890
    Flash: 11 C (52 F)
    Melt: -98 C (-144 F)
    Boil: 64.1 C (147 F)
    Auto-Ig: 463 C (867 F)
    Cost: $42.00 for 4 Liters.
    CAS#: 67-56-1
    Stable: Yes
    A colorless, flammable, poisonous liquid having a slight alcohol
    odor when pure. Miscible
    in water, ethanol, ketones and most other organic solvents. Can be
    used with glass, LDPE,
    HDPE, polymethylpentene, PVC, polystyrene, Teflon, nylon,
    polypropylene, urethane, or neo-
    prene.
    Meth/Water was selected by one knowledgeable researcher. It
    consists of distilled water
    and 20% methyl Alcohol along with ferric nitrate in the amount of 10
    to the -17 gm mols per
    liter. This solution is four times faster than pure methyl alcohol.
    (See Posting # 88.)
    Is it possible that the ferric nitrate has the purpose of keeping
    down on the acquisition
    of more oxygen molecules. Can be used with urethane.
    Mobil 1. Majority of compound is polyalphaolefin (PAO). I am
    guessing that maybe close to
    C10H20 for the polyalphaolefin. Problem is that any motor oil will
    contain 1--20% addi-
    tives which may cause problems. All oils will contain Ca, Mg, Zn,
    S, P, N, Cl, O and may
    contain Mo, Na, or even Ba. Most of the alkaline metals are in the
    formulation as sus-
    pended carbonates which might also present a problem.
    Prod# S.G. PoursF CranksF FlashF Visc.
    0W-30 48116-8 .860 -54 -30 238 176
    5W-30 48111-9 .862 -54 -25 235 162
    10W30 47117-6 .866 -54 -20 243 147
    15W-50 48120-0 .875 -48 -15 245 160
    Mobil 1 SEEMS to have about 80% of PAOs. Generally all synthetic
    motor oils are composed
    of four basic components; 1. PAO base oil 2. ester 3. VII to produce
    multi grades 4. addi-
    tives. PAO is a tetramer of decene molecules which is then
    hydrogenated. Basically, it is
    composed entirely of carbon and hydrogen and therefore has the
    greatest proportion of hy-
    drogen atoms. PAOs are manufactured according to their viscosity at
    100 Celsius. PAO-4 is
    a relatively thin oil like a 5W-30 but DOES have a flash point well
    above 200 F. Esters
    contain carbon, hydrogen, and oxygen and contain a lower proportion
    of hydrogen. Mobil
    uses a higher proportion of PAO, where some others like Amsoil tend
    to formulate with a
    higher level of ester. Lubricating oil is a medium weight material
    that flows easily and
    is easily dispersed if treated promptly. This oil has a low
    volatility and moderate flash
    point, but is fairly persistent in the environment. Can be used
    with urethane.
    Naphta is used by Amherst College Geology Department in their
    Geonics magnetometer.
    Nonane {4.04}
    Formula: C9 H20
    Mol. Wt.: 128.257
    #H Atoms: 20
    Density: 721
    Chi:H2 O: 1.012
    Flash: 31 C (87 F)
    Melt: -53 C (-63 F)
    Boil: 150.8 C (303 F)
    Auto-Ig:
    Cost: Prohibitively expensive.
    CAS#: 111-84-2
    Stable:
    Colorless, flammable liquid.
    Octyl Alcohol (1-Octanol) {6.162}
    Formula: CH3 (CH2)6 CH2 OH
    Mol. Wt.: 130.2296
    #H Atoms: 18
    Density: 826
    Chi:H2 O: 1.027
    Flash: 81 C (176 F)
    Melt: -15 C (0 F)
    Boil: 195 C (385 F)
    Auto-Ig: 272 C (523 F)
    Cost: $35.50 for 1 Liter.
    CAS#: 111-87-5
    Stable: Yes
    2,2'-Oxybisenthanol (Diethylene Glycol) Chi .948
    Oxygen. Free oxygen in solution is paramagnetic; free nitrogen is
    not. When filling the
    bottle before encapsulation, dissolved oxygen may be driven off by
    bubbling pure nitrogen
    through it for 20 minutes or by boiling it. At this point in time I
    see the basic solution
    as keeping oxygen out of the liquid and having a liquid which repels
    oxygen. I am also
    considering (but I don't know how) pressurizing the container of the
    proton rich fluid.
    PAO-4 (Polyalphaoleofin-4)
    Formula:
    Mol. Wt.:
    #H Atoms:
    Density:
    Chi:H2 O:
    Flash:
    Melt:
    Boil:
    Auto-Ig:
    These "Durasyn" products MIGHT be the base stocks used for Mobil 1
    but without the objec-
    tionable additives. PAO-4 is a 4 c5t @ 100C (viscosity measurement)
    produced by reacting
    butene and hexene to form a tetramer around a centroid. The
    resulting molecule contains a
    single double bond which is then hydrogenated to produce a molecule
    with exclusively
    aliphatic hydrocarbon. I believe the ratio is 3:1 hexene:butene,
    but I am not sure. The
    resulting molecule is in the C20 number range. You can probably
    purchase some of this
    through Sigma-Aldrich. If not, the domestic supplier is Amoco
    Chemical;. If you want a
    slightly more viscous fluid move up to PAO-6 which is produced using
    hexene and decene I
    believe. PAOs are all hydrocarbon structures, and the contain no
    sulfur, phosphorous or
    metals.
    Paraffin Oil
    Formula:
    Mol. Wt.:
    #H Atoms:
    Density:
    Chi:H2 O:
    Flash: 150 C????
    Melt:
    Boil:
    Auto-Ig:
    The general formula for Paraffin is Cn H2n +2 with "n" usually
    greater than 19. Can be used
    with glass, PVC(Type 1), Teflon, nylon, polypropylene or Viton. The
    generic name of these
    products is quite confusing because "Paraffin Oil" is what Kerosene
    is called in Great
    Britain. Generally speaking in the United States "Paraffin Oil" is
    some type of mineral
    oil.
    Pentane {3.748}
    Formula: CH3 (CH2)3 CH3
    Mol. Wt.: 72.15
    #H Atoms: 12
    Density: 626
    Chi:H2 O: .937
    Flash: -49 C (57 F)
    Melt: -129 C (-202 F)
    Boil: 36 C (98.6 F)
    Auto-Ig: 260 C (500 F)
    Cost: $45.20 for 500 ml.
    CAS#: 109-66-0
    Stable: Yes
    A hydrocarbon of the paraffin series. Can be used with Teflon,
    nylon or viton.
    Pentanol (See Amyl Alcohol) There are eight different substances
    with the formula C5H12O
    but with different structures. CAS 71-41-0 is usually described as
    C5H11OH. Melts at -108
    C, Boils at 137.9 C, Flash point is 32 C. Slightly soluble and
    hygroscopic. See listing
    under Amyl Alcohol.
    1,3-Propanediamine {2.156}
    Formula: C3 H10 N2
    Mol. Wt.: 74.1254
    #H Atoms: 10
    Density: 888
    Chi:H2 O: 1.078
    Flash: 48 C (120 F)
    Melt: -12 C (10 F)
    Boil: 140 C (284 F)
    Auto-Ig:
    Cost:
    CAS#: 109-76-2
    Stable:
    Water white, mobile liquid which is hygroscopic.
    Propanol C3H8O mw 60.095, Melts at -126 C Boils at 97.2 C,
    Density .803, Flashpoint 15
    C. This is a flammable liquid which is miscible and hygroscopic.
    Dangerous flashpoint.
    1,2-Propandiol C3 H8 O2 mw76.1 Melts at -59 C and boils at 189 C
    1,2,3-Propantriol C3 H8 O3 mw92.1? Melts at 18 C and boils at 290
    C.
    Propylene Diamine {4.224}
    Formula: C3 H10 N2
    Mol. Wt.: 74.1254
    #H Atoms: 10
    Density: 870
    Chi:H2 O: 1.056
    Flash: 33 C (91 F)
    Melt: -37.2 C (-35 F)
    Boil: 120.5 C (249 F)
    Auto-Ig:
    Cost:
    CAS#: 78-90-0
    Stable:
    Colorless, flammable, hygroscopic liquid which is very soluble,
    strongly alkaline with an
    ammoniacal odor.
    Propylene Glycol (1,2 Propanediol) {5.88}
    Formula: C3 H8 O2
    Mol. Wt.: 76.094
    #H Atoms: 8
    Density: 1036
    Chi:H2 O: .980
    Flash: 107 C (225 F)
    Melt: -59 C (-74 F)
    Boil: 185 C (365 F)
    Auto-Ig: 371 C (700 F)
    Cost: $210.20 for 4 Liters.
    CAS#: 57-55-6
    Stable: Yes
    Water absorbs 10g/100mL of PG at 21 C. Clear colorless, viscous
    liquid which is hygro-
    scopic. Low molecular weight (why?) and high density gives this a
    high Chi but I am con-
    cerned about the two oxygen atoms. [The O2 is NOT free, it is
    divided into two alcohol
    functional groups.] It can hydrogen bond with water, so that will
    make it hygroscopic, and
    I would suspect it is somewhat soluble in water. Now, as for oxygen
    in the air, most liq-
    uids, regardless of composition, will acquire water in general.
    This is mostly because of
    the fact that the atmosphere "pushes" the air downwards into the
    solution, and some (al-
    though not a lot) will end up interacting with the liquid by London
    dispersion forces
    (these are really the only forces available to O2, as it is
    non-polar). Oxygen is somewhat
    reactive, though, as it is a diradical, I would not imagine PG
    reacting significantly with
    oxygen, any more than say, ethylene glycol or ethanol. This is
    Henry's Law of Gas Solubil-
    ity. Can be used with glass, LDPE, HDPE, PP, polymethylpentene,
    polystyrene, Teflon or viton.
    4-Oxo-TEMPO, free radical (Tempone)
    Formula: C9 H16 NO2
    Mol. Wt.: 170.23
    #H Atoms: 16
    Density:
    Chi:H2 O:
    Flash:
    Melt:
    Boil:
    Auto-Ig:
    Cost:
    CAS#: 2896-70-0
    Expensive and unstable. I have heard that commercial units have to
    be periodically re-
    turned to the factory to be recharged with Tempone. The advantage
    of Tempone in Overhauser
    mags is that it can be continuously polarized thus producing a
    continuous magnetometer out-
    put signal. A stable free radical, in the form of an orange,
    crystalline powder at room
    temperature. Often referred to as
    4-oxo-2,2,6,6-teramethyl-1-piperidinyloxy, free radical,
    it is soluble in water and many organic solvents. Incompatible with
    strong oxidizing
    agents. One supplier quotes a price $25.30 per gram. Lee Fraser
    said (Posting #217) that
    only a tiny amount is required so maybe it can be added to almost
    any liquid to decrease
    polarization time???? (Is it possible that this is just an additive
    used to decrease po-
    larization time?)
    1-Tetradecene {4.945}
    Formula: C14 H28
    Mol. Wt.: 196.3752
    #H Atoms: 28
    Density: 771
    Chi:H2 O: .989
    Flash: 115 C (239 F)
    Melt: -13 C (9 F)
    Boil: 251 C (483 F)
    Auto-Ig:
    Cost: $28 per Liter.
    CAS#: 1120-36-1
    Toluene {1.989}
    Formula: C6 H5 CH3
    Mol. Wt.: 94.14 (92.14 in EMS - prob their error.)
    #H Atoms: 8
    Density: 867.0
    Chi:H2 O: .663
    Flash: 4 C (39 F)
    Melt: -93 C (-135 F)
    Boil: 110.6 C (231 F)
    Auto-Ig: 480 C (896 F)
    Cost:
    CAS#: 108-88-3
    Stable: Yes
    Colorless liquid with an aromatic odor like benzene. Can be used
    with glass, Mylar, nylon
    or Teflon.
    Trimethylene Glycol (1,3 Propanediol) {5.982}
    Formula: C3 H8 O2
    Mol. Wt.: 76.095
    #H Atoms: 8
    Density: 1053
    Chi:H2 O: .997
    Flash: 131 C (246 F)
    Melt: -27 C (-17 F)
    Boil: 214 C (417 F)
    Auto-Ig: 400 C (752 F)
    Cost: 39.50 for 250 mL.
    CAS#: 504-63-2
    Stable: Yes
    Clear, colorless liquid with no odor.
    Water (distilled) H2O 18 2 1000.0 1.00. Viscosity is (at 20C)
    is 1.00 x 10 -three. I
    now see mention of "Water,Distilled, Lab Grade 7" and the note that
    PVC(Type 1), Teflon, nylon, polypropylene or viton. Tygon and
    neoprene are usable but not
    recommended.
    Water & 20% Methyl Alcohol et al.
    Water H2O 18 2 1000.0 1.000
    Xylene (Dimethylbenzene) {3.04}
    Formula: C6 H4 (CH3)2
    Mol. Wt.: 106.167
    #H Atoms: 10
    Density: 897.0
    Chi:H2 O: .760
    Flash: 32 C (80 F)
    Melt: -25.2 C (-13 F)
    Boil: 144 C (299 F)
    Auto-Ig: 463 C (865 F)
    Cost:
    CAS#: 95-47-6
    Stable: Yes
    Can be used with Teflon or nylon.
    ALCOHOL: An organic compound having a hydroxyl (-OH) group
    attached. The lower molecular
    weight, methanol (CH3OH), ethanol C2H5OH), and propanol (C3H7OH) are
    water soluble.
    ALIPHATIC: One of the main groups of hydrocarbons characterized by
    the straight or
    branched chain arrangement of constituent atoms. Aliphatic
    hydrocarbons belong to three
    subgroups:
    1. Alkanes or paraffins, all of which are saturated and
    comparatively unreactive.
    2. The alkenes or alkadienes which are unsaturated (containing
    double [C=C] bonds) and
    more reactive.
    3. Alkynes, such a acetylene (which contain a triple [C=C] bond).
    ALKANE: An aliphatic hydrocarbon having the chemical formula
    CnH2n+2. A normal alkane, or
    n-alkane is one which does not have a branched carbon backbone. An
    iso-alkane has a
    branched, rather than a straight chain, carbon backbone. Alkanes
    are also known as PARAF-
    FINS. The simplest alkanes are as follows; CH4 methane, C6H14
    hexane, C2H6 ethane, C7H16
    heptane, C3H8 propane, C8H18 octane, C4H10 butane, C9H20 nonane,
    C5H12 pentane, C10H22
    decane.
    COMBUSTIBLE LIQUID: A liquid which is capable of forming a
    flammable vapor/air mixture.
    All flammable liquids are combustible.
    DIESEL FUEL: Diesel Fuel consists mostly of hydrocarbons ranging
    from C10 to C24. The
    composition of diesel fuel may vary with changes in latitude or
    changes in season. This
    variability is provided by the refinery to control the volatility of
    the product. In order
    to be identified as diesel fuel, a sample extract must exhibit a
    homologous series of five
    or more consecutive alkanes ranging from C12 through C22. Diesel
    fuel has a flash point of
    120 to 160 F and explosive limits of 0.7 % to 5 %. Many states
    specify a minimum flash
    point for diesel fuel.
    FLAMMABLE LIQUID: A combustible liquid that has a flash point below
    100 F.
    FUEL OIL: A heavy petroleum distillate ranging from #1 (Kerosene or
    range oil), #2 (diesel
    fuel), up through #6 (heavy bunker fuels). To be identified as fuel
    oil, a sample must ex-
    hibit a homologous series of normal alkanes ranging from C9 upward.
    GASOLINE: A mixture of more than 200 volatile hydrocarbons in the
    range of C$ to C12,
    suitable for use in spark ignited internal combustion engines.
    Regular automotive gasoline
    has a flash point of -40 F.
    ISOPARAFFINS: A mixture of branched alkanes usually available as a
    narrow "cut" of distil-
    lation. Exxon manufactures a group of products known as 'Isopars'
    ranging from Isopar A
    through Isopar J. These solvent mixtures have a variety of uses.
    Gulf Oil manufactures a
    similar series of solvents, the most commonly available being Gulf
    Life Charcoal Starter
    Fluid which is roughly equivalent to Exxon's Isopar G.
    MINERAL SPIRITS: A medium petroleum distillate ranging from C8 to
    C12. The flash point of
    mineral spirits is generally around 100 F. Mineral spirits, also
    known as mineral turps,
    stoddard solvent, white spirits or safety solvent is commonly known
    as a solvent in insec-
    ticides and certain other household products. Many charcoal lighter
    fluids are composed
    almost entirely of some form of mineral spirits. It is not soluble
    in water.
    NAPHTA: This term is so ambiguous that it should not be used.
    OLEFIN: An alkene. An organic compound similar to an alkane, but
    containing at least one
    double bond. Olefins have the formula Cn (H2)n where "ne" is the
    variable. The simplest
    olefin is ethylene, C2H4.
    PETROLEUM DISTILLATES: By-products of the refining of crude oil.
    Low boiling or light pe-
    troleum distillates (LPD) are highly volatile mixtures of
    hydrocarbons. These mixtures are
    sometimes called ligroin, petroleum ether, or naphtha. LPDs are
    used a lighter fluid,
    copier fluid, and as solvents. Medium boiling petroleum distillates
    (MPD) are sometimes
    known as mineral spirits, and are used as charcoal starters, as
    paint thinners, as solvents
    for insecticides and other products, and as lamp oils. High boiling
    or heavy petroleum
    distillates (HPD) are combustible liquids such as kerosene and
    diesel fuel.
    In Canada, flammable liquids are divided into the following classes:
    3.1 - Flash point less than -18 C (-.04 F)
    3.2 - Flash point not less than -18 C and less than 23 C (75.4 F)
    3.3 - Flash point not less than 23 C and less than 61 C (141.8 F)
    Apparently anything with a flash point greater than 61 C (141.8 F)
    is NOT (in the legal
    sense) hazardous liquid and seemingly no restrictions apply.
    U.S. standards SEEM similar but are even more confusing than the
    Canadian regulations to
    me. Class IIIa >140 F (60 C) and 200
    F and SEEMINGLY is not
    covered by any regulation.
    Therefore, if possible, the flash point of any proton rich fluid
    should be >200 F (93.3 C)
    if possible. If that standard cannot be met then the flash point
    should be at least >61 C
    (141.8 F). Because of safety concerns, I personally believe I would
    not use anything with
    a flash point lower than that.
    Some considerations for proton rich substances: The proton bearing
    liquid must have a high
    composition of hydrogen atoms and its relaxation time should be such
    that the signal to
    noise ratio is sufficient at the end of the measurement period; but
    not too long that the
    polarization time drains the battery too much. ONLY hydrogen atoms
    count!!! The proton
    liquid must be able to withstand adverse conditions ... 120 F to -20
    F... If the liquid is
    frozen, NOT ONLY IS THE SIGNAL LOST, but the resulting expansion may
    burst the encapsula-
    tion. ... Methyl alcohol is a good compromise ... or .... If
    however a very fast repeti-
    tion rate is required a different solution is used. By using a very
    small addition of a
    ferric salt both the polarization and relaxation times can be
    reduced. For this purpose we
    use a 20% solution of methyl alcohol in distilled water containing
    10 to the -17 gm mols
    per liter of the ferric nitrate. This solution is four times faster
    than pure methyl alco-
    hol. (See Posting # 8.
    Roger Dewhurst speculates that the signal is lost because the
    Hydrogen atoms are not free
    to vibrate when frozen and this is substantiated by another expert.
    "According to the molecular theory, the molecules of water, which in
    the liquid form have
    considerable movement, have to occupy definite relative positions
    when the water assumes
    the form of ice. When pure water is cooled to 0 degrees Celsius,
    the energy of the mol-
    ecules is sufficiently diminished to allow attractive forces to come
    into play under which
    the molecules assume the positions required for freezing but the
    presence of salt ... hin-
    ders... But paraffin contracts when freezing, so maybe different
    (maybe even worse) than
    water in this respect.
    "The precession of hydrogen atoms in water only occurs because of
    the hydrogen bonding (hy-
    drogen attraction to electrons) and the polarity of the water
    molecule (it has positive and
    negative regions). Once water forms a solid (ice) the dipole
    interactions and hydrogen
    bonding occurs with other water molecules instead, thus the water
    molecules are tied up
    with one another and cannot be attracted to another force."
    And yet another opinion: Yes, the hydrogen atoms will still precess
    when the water is fro-
    zen. Really, it's not the whole atom, just its magnetic moment
    which is precessing around
    the created field. This is the same phenomenon which makes magnetic
    resonance imaging
    (MRI) and nuclear magnetic resonance (NMR) spectroscopy possible.
    (tjh)
    HYDROGEN BONDING
    Figure 11.6 shows the boiling points of the simple hydrides of group
    4A and 6A elements.
    In general, the boiling point increases with increasing molecular
    weight, owing to in-
    creased dispersion forces. The notable exception to this trend is
    H2 O, whose boiling
    point is much higher than we would expect on the basis of its
    molecular weight. NH3 and HF
    also have abnormally high boiling points. These compounds also have
    many other character-
    istics that distinguish them from other substances of similar
    molecular weight and polar-
    ity. For example, water has a high melting point, a high heat
    capacity per gram, and a
    high heat of vaporization. Each of these properties indicates that
    the intermolecular
    forces between H2 O molecules are abnormally strong. HYDROGEN
    BONDING is a special type of
    intermolecular attraction that exists between the hydrogen atom in a
    polar bond (par-
    ticularly and H--F, H--O, or H--N bond) and an unshared electron
    pair on a nearby
    electronegative atom (usually and F, O, or N atom on another
    molecule). For example, a hy-
    drogen bond exists between the H atom in an HF molecule and the F
    atom of an adjacent HF
    molecule, F--H...F--H (where the dots represent the hydrogen bond
    between the molecules).
    Several additional examples are shown in Figure 11.7.
    Hydrogen bonds can be considered unique dipole-dipole attractions
    because F, N, and O are
    electronegative, a bond between hydrogen and any of these three
    elements is quite polar,
    with hydrogen at the positive end:
