Sv: Transistors used in Huggard Proton Magnetometer??
  • Sv: Transistors used in Huggard Proton Magnetometer??
    Thank your for your informations - i will try to work on the construction.
    Henrik
    -----Oprindelig meddelelse-----
    Fra: Oliver Krayl
    Til: The Proton Mag Forum
    Dato: 1. december 2000 22:30
    Emne: Re: Transistors used in Huggard Proton Magnetometer??
    >Hello Henrik,
    >I found following Info in my Library about the Transistors:
    >2N5088, NPN-Silicon, VCEOm: 30Vdc, Icm: 50mA, Pd: 625mW, fT: 50MHz,
    >hfe: 350~1400 -> Motorola Type (pdf-avail.)
    >For these ones I got only short Descriptions
    >[Material,Type/App,(VCEm,Icm,Pdm),equivalents):
    >2N2712, NPN-Silicon, B>75 equiv: 2N2711,BC168,BC183,BC238,BC548...
    >2N2613, PNP-Germanium, LF-Type, 30V, 0,05A, 0,12W equiv:
    >AC125..126,AC151,2SB54,2SB56
    >2N2643, NPN-Silicon, Dual-Type ! ,45V,0,03A,0,5W, ft>40MHz equiv:
    >BFY81,2N2913..20
    >2N404, sorry no Info available (perhaps obsolete)
    >Greetings
    >Oliver - Germany
    >Valentin Mortensen wrote:
    >> The Proton Mag ForumAfter looking at several different suggestions how
    >> to build a differential proton mag. it looks to me that the simple way
    >> is the "Huggard" way (the articel from 1970). But since I am not a
    >> electronical expert, I have some problems to get the transistors.
    >> Anyone have an idee how to the
    >> transistors?2N50882N27122N26132N26432N404or transistors that
    >> correspond to the one used in the construction.Henrik - Denmark
