Measuring Magenetite field strength
  • Measuring Magenetite field strength
    what magnetometer would i need to use if i wish to measure the field strength of a piece of magnetite. by piece i mean i have poured crushed magenetite into a mould and mixed it with water to harden and now i wish to know the magnetic field strength produced by this larger piece of magenetite.
    would i need to use the proton magnetometer or the flux gate
    Cheap gauss meter
    http://planet.gcn.ou.edu/gravmag/mag_rock/mag_rock.html
    Cheap gauss meter with UGN3503
    http://my.execpc.com/~rhoadley/magmeter.htm
    http://www.thunting.com/cgi-bin/geot...e=projects.dat
      thanks
        EDN article
        http://www.edn.com/archives/1996/031496/06df2.htm
        ¿Only OPAMP and inductor? easy magnetometer/microcontroler PIC
          I would use a proton / cesium type mag so you don't have directional issues. Set it up in a magnetically quiet spot and take a reading. Then move the magnetite in and take a reading. Then subtract reading 1 from reading 2.
          But if you want to know the purity of your sample, you should determine its mass by taking a sample of a known volume and weight. Then take a magnetic susceptibility reading with a Bartington MS2 or similar instrument. The magnetic susceptibility will have a strong influence on its field strength.
