Autotransformer
  • Autotransformer
    >on the db test-if the person being tested can not
    >even meet that which statistics say should be---
    >that is to say--at extreem---if he never ever,no
    >matter how many times he does a "run"--finds the
    >target,,score 0 out of 10000---is this then to
    >say perhaps the participant should change his
    >tactic and if he thinks/feels/detects or whatever-
    >a target to disregard this and if "no" is the
    >find to call this as the target----(inverse detect)
    >or is this to say the statistics are in error----
    >(the math) or that the participant is playing
    >games (not being truthfull to color the results)
    >or what ?????????
    I got a little confused about the last part of your question. But if a dowser (or an LRL-er of MFD-er or whatever you want to call it) can't do any better than someone who guesses in a DB test then it's not time to change test methodologies to try and get better results - it's time to seriously question whether the device works in the first place.
    Re: ? for carl
    got it--thanks to explain more for me..sorry for my selection of words to beunclear---it seems though that thegeneral position of a lot of lrl userswhen bad results is to "have a reason"well the moon was not full..or ....or to cry foul--or...to me-just try tounderstand...
    reg-rick
    >>on the db test-if the person being tested can not>>even meet that which statistics say should be--->>that is to say--at extreem---if he never ever,no>>matter how many times he does a "run"--finds the>>target,,score 0 out of 10000---is this then to>>say perhaps the participant should change his>>tactic and if he thinks/feels/detects or whatever->>a target to disregard this and if "no" is the>>find to call this as the target----(inverse detect)>>or is this to say the statistics are in error---->>(the math) or that the participant is playing>>games (not being truthfull to color the results)>>or what ?????????
    >- Carl
      Re: ? for carl
      >understand...
      Yes, there are a lot of excuses for failure, but each and every one of these reasons are testable as well. Which makes me wonder why many dowsers are so hostile to testing, when it provides so much useful information.
        Autotransformer
        In the schematic of the PW.Sandbanks PI Metal Detector the part TOKO 87BX135 is used . Can anybody help me to find a place where this part can be bought , or is there a replacement for it . The TOKO manufacturer is not aware of the existence of this part . Kind of puzzles me now . Regards and thanks for info . Cornelius . alhaor@wanadoo.nl
          Re: Autotransformer
          Build the proscan or use any transformer of the old radio transistor
            Re: Autotransformer
            Carlos . In combination with a c.m.o.s. it forms a voltage inverter . I guess we misunderstood eachother . Regards Cornelius
              Re: Autotransformer
              Hello Cornelius, when I build the Sandbanks memory to have used a trasnformator that I obtained from an old radio to transistors. My respect
              Carlos.
                Re: Autotransformer
                Carlos . I did work with the 1:1 transformer from a transistor radio . Thanks . Cornelius
