Cylindrical Toroid
  • Cylindrical Toroid
    Is it necessary to build the toroid out of a plastic material?
    Would a nonferous metal ie: Aluminum or Copper function properly?
    Does anyone have a PPM operating with the control scheme designed by Jim Koehler? How does it perform?
    Thanks for the input. Ken
    Re: Cylindrical Toroid
    Ken,
    I believe the problem with copper or aluminum is that it will appear as a shorted turn. You could probably use it if it had a slit around the entire circumference, but then you would have to fill the slit with something to keep your fluid in.
    Jeff
