Interpreting my Mag survey
    Hi Subscribers,
    From some years until now I have made sea bottom mag surveys using the proton mag MX500 - a proton mag with a torus shape coil.
    As diver, I know must of the underwater anomalies and I build up a good feeling about mag signature correlated with the ferrous remains.
    The MX500 can read two ways, simple mag readings (1, 2 or 3 seconds polarizing time) or pseudo gradiomiter performing time shift readings (1,2 or 3 seconds). This is the best option for igneous rocky (black sand) terrain.
    The mags are good devices but, like here over granite continental shelf, supposedly do not existing black sand or igneous rocks (basalt) the anomalies must be correlated with some kind of magnetic material.
    It hapens in some places, I have a high gama readings (half thousand gamas) both in simple mag and grad on a very well delemited area (100 meters long by 40 large). And nothing more than the granite rocky bottom all around (40 meters deep)!!!
    It is impossible to exist some kind of ferrous material sunken, the bottom is completely rocky (granite - nom magnetic !) with some litle mudy sockets.
    Any of you have such readings on the same evironmental conditions ?
    On diferent kind of bottom plenty of old lost anchors and steel fishing garbage, acurate readings like one gama and below, is a dream and time consuming. So very sensitive magnetometers will sense all this mag field shifting and it will be a inutile search.
    Greetings
      Francisco,
      Sounds like you are having a lot of fun!!! I am jealous! GRIN
      That is quite a large area.
      Here in the US I have a problem with the granite. I always thought it was because of the black sand in the granite.
      BUT MAYBE NOT.
      Here in Texas I went prospecting at the Llano river. Thought I would be able to find black sand deposits. The Mag was useless... The river has a lot of granite and the mag went crazy everywhere. I had the same problem in California in the American river. When I got away from the granite in the bed of the river I was ok and was able to find some pockets but down in the river where the granite was I could not tell anything.
      I think you are detecting the granite. Granite IS an intrusive igneous rock.
      That means that at one time it WAS molten and at that time the molecules would have aligned with whatever the earths magnetic field was and be frozen in that orientation when it cooled. A huge weak magnet.
      If you have not done it already, my suggestion would be, if possible, to break off a piece of the granite and take it up on land so you can play with it and verify that it truly is NOT magnetic. (I know you said it is NOT magnetic! But I've found some of the strangest things that I thought were not magnetic.) Even found a stone arrow head that was magnetic.
      I found a place in New Mexico that has just the opposite effect. The magnetometer readings drop suddenly and continue to drop extremely low before it starts to go back up again.
      I have a 1/2 pound of iron burried that I can't detect. Did not understand it at first. It is a piece of metal rod (rebar) 3/8 inch in diameter that I got from a scrap yard. I took it and bent it until it was about 4-5 inches long and then buried it 1 foot deep. I can't detect it. The reason is that it had been handled by one of those big magnetic cranes and it was magnetized.
      When I bent it and burried it two things had to happen. I, by chance, bent it so that the magnetic field partially cancelled out and then when I buried it I accidentally put it in a direction so that any affect on the earths magnetic field by the iron was cancelled by the magnetism. The lesson is, beat the heck out of anything you bury with a big hammer to knock out the magnetism before you bend an bury it.
      If you scroll down the page at the following link there is a gray scale mag map where you can see the missing iron. There should be four pieces of iron in the two columns. You can see that one is missing in the first column.
      http://home.comcast.net/~dcyoung9/fpa/Magnetometer.html
      Here is something neat:
      Sheldon Breiner is founder of Geometrics.
      http://www.breiner.com/sheldon/olmec/
      Sometime strange things happen...
      Don
