Scenario #1 - Sam Scafferi's will bury his Mason jar of silver coins on a 1-acre junk yard... see if your mags can pick it up if he buries it just one inch below the surface.
Scenario #2 - Sam Scafferi's will bury his Mason jar of silver coins on a 1-acre farm... see if your mags can pick it up if he buries it just one inch below the surface.
Scenario #3 - Sam Scafferi's will bury his Mason jar of silver coins on a 1-acre heavily forested with heavy underbrush, briars, and brambles... see if your mags can pick it up if he buries it just one inch below the surface.
Scenario #4 - Sam Scafferi's will bury his Mason jar of silver coins on a stretch of Gulf Beach... see if your mags can pick it up if he buries it just one inch below the surface.
Oops! Did I tell you that both Sam and Carl require anyone wanting to trot out to each of these scenarios to take two PROPER tests:
#1: Pass the jar of silver coins past you mag (air test)... if it registers then you are qualified for the Treasure Hunt if you past the next test.
#2: Place the jar of silver coins under just one of 10 paper plates in any field. The other nine paper plates may or may not cover metals. You must then be subjected to a qualified DOUBLE-BLIND TEST by certified scientific testors. If you can find the jar of silver coins in 6 out of 10 attempts then you are better than RANDOM CHANCE, and you now qualify to go into each of these scenarios with your wiz-bang contraptions.
Good Luck!!!!!!!!!!!!
Larry Stier
Larry Stier
