GSM-19 DGPS ..i need help on post processing
  • GSM-19 DGPS ..i need help on post processing
    basically i was asked to test a new mag with a dgps system.
    differential global positioning system
    running the mag and getting good data was the easy part .."i've been magging for 20 years ".. trying to post process the data is the part i'm stuck on
    does anyone know how the heck i dump the data in a format that i can diferentially correct the data using a trimble base station or differential data i have from another gsm-19 dgps system.
    the output from the mags is in plain text and i also can dump the contents of the memory as a .bin file.
    no gps software i can see will recognize plain text as valid gps data and no software recognizes the binary files.
    can anyone point me in the right direction to post process my dgps data
    Do you store the data in a Trimble DGPS rover station? If so then it is easy. If not how do you save the data?
      devolution
      job's over ..i could not give him dgps data and besides both dgps mag's broke down so i used hand held gps data while magging.
      8m accuracy is better then none
